Question about RCA RT2280 System
Sound (Audio) Drops Out
For about the last six months our RT 2280 system has experienced an unexplained, but growing problem with audio drop out. The system will be playing correctly using either directv tv, VCR or DVD and the sound will suddenly drop out (go silent), while the video continues. At first it occurred no more than once a day, but now it occurs regularly three to four times an hour. Ideas?
  • 4,234 Answers
This unit is shutting down the outputs probably due to heat. There are thermal detection transistors inside that will shut off the output amp section if it gets too hot. There can be a number of reasons for this. Check the speaker wires to be sure that they are not frayed at all and that none of the strands are touching. Other than that there may be defective parts inside that are sensitive to heat.
Dan
Posted on Jul 15, 2008
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
My tv keeps losing sound why?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 08, 2015 | Televison & Video
I have a Rosen Piranah Navigation/CD/DVDEntertainment system. Everything was professionally installed over two months ago. All was working well today until I all of a sudden lost audio/sound. What ha
if its only 2 months old take it back you get a years warenty with audio equipment and fitting dont take no for an answer get them to put it right
Oct 23, 2012 | Cars & Trucks
Low power with max volume
The audio output ic may have to be replaced, usually when sound drops and distorts it is a good indicator of a bad ic.
Mar 07, 2012 | Audio Players & Recorders
I have a SAmsung HTZ310R home cimema system and recently been experiencing audio drop out. I stream movies from my PS3, and play BD's, watch DVD's. Havent had any issues until recently, when sound started...
Sounds like a couple of coincidental but unrelated symptoms.
Optical cables need precise seating and no tight bends.
Muffled, channel-specific sound is usually on the analog end. Speaker connections maybe.
Mar 17, 2010 | Audio Players & Recorders
Does the 2005 GX470 Lexus play mp3 files?
Audio & Entertainment Audio System Lexus Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, six-disc CD auto-changer Speakers 11 Audio System Mark Levinson® [3] Premium Audio System with Automatic Sound Levelizer (ASL) and six-disc DVD/CD auto-changer Optional
Speakers 14 Optional
Watts 240 @ 0.01% THD, 20-20,000Hz [21] Optional
MP3 Audio Input Plug MP3 audio input plug Rear Audio Rear-Seat Audio System (RSAS) Optional
Antenna In-glass antenna with FM-diversity system Satellite Radio XM® Satellite Radio capability [22] Optional
DVD Entertainment System Lexus DVD Rear-Seat Entertainment System (RSES) Optional
Wireless Headphones Included with DVD Rear-Seat Entertainment System (RSES) [23] Optional
http://www.lexus.com/cpo/model_library/GX/2007.html Wheen you click this link scroll to the bottom of the page. It will be under Audio & Entertainment.
Mar 14, 2010 | Sony MHC-GX470 Shelf System
RCA 2280 Optical Input w/PS3
The only optical option is through the satalite function. After I hooked up my xbox 360 with optical audio, I pushed the SAT button on the front of the RCA receiver then turned the multi jog wheel until it read "optical" out came surround sound. I hope this helps you.
Dec 07, 2008 | RCA RT2280 System
I have picture and no sound
Try unplugging it for a minute. You will have to go through setup again (most likely).
Some of these sets have a (software?) issue and the audio drops out maybe once or twice a year-at least that's what I've experienced. No real fix for it.
Aug 01, 2008 | GE 35GT720 35" TV
Great picture no sound
Youre audio output IC is probaly defective. Try replacing the IC its only a few dollars and thats usually the problem with that chassis when audio drops out completely.
Apr 09, 2008 | Televison & Video
Auidio drops
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Jun 20, 2007 | Sony Handycam DCR-TRV900 Mini DV Digital...
RCA RT2280 System Logo
143 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
