Question about LG LD65EL Dehumidifier
MY LG DEHUMIDIFIER WILL NOT LOWER THE HUMIDITY
IT WORKED GREAT LAST YEAR GALLONS OF WATER EVERY WEEK WAS SUCKED UP. sTARTED IT UP THIS YEAR AND NOT A DROP OF WATER IN THE BUCKET, I KEEP EVERYTHING NICE AND CLEAN , AND IN GREAT CONDITION, THIS IS MY THIRD DEHUMIDIFIER IN 4 YEARS, WHAT IS HAPPENING?
    Novelist:
  • 121 Answers
Make sure that the filter and coils are clean. LG recommends that you clean the filter every 2 weeks. They also include a brush to clear the dust from the coils. If this does not solve the issue it will need to be serviced. If it needs to be serviced this dehumidifier has a 5 year warranty. If it is under 5 years old contact LG and they will either offer to have it serviced by a nearest service center or send you a replacement if a service center is not nearby.
Posted on Aug 04, 2008
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
I have a Kenmore 54501 Dehumidifier. Just plugged it in today and it runs but no water is in tank. What could the problem be? It worked great last summer and was not plugged in all winter.
You may have the humidity extraction level set higher than the humidity level in the house. Lower the level to 32 to 35%. Also, remove and check the air intake filter for dirt or clogs. Clean if necessary.
Hope this helps you solve the problem.
Jun 09, 2011 | Kenmore 54501 Dehumidifier
Up to this year it worked fine. I just turned it on last week and it is not drawing any water and let me tell you it is humid here in Virginia
heatman101
Jun 01, 2011 | LG LHD45EL Dehumidifier
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
Hope this helped you.
May 10, 2011 | LG LHD45EL Dehumidifier
I purchased a 45 pint/day dehumidifier model # DD45P last year and it worked great. We needed to empty it almost every day as it was located in our lower level at a lake home. We have just returned to our...
heatman101
Apr 11, 2011 | DeLonghi Dehumidifiers
Good morning. I have a DeLonghi DEM10 Dehumidifier. I had not used it since last winter and last week put it back on. It apperas to be functioning as normal (switching on and off), however the tank...
Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
Nov 14, 2017 | DeLonghi Dehumidifiers
No water accumulating
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 06, 2010 | LG LHD45EL Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
Dehumidifier Present % indicates "Hi"
It is showing high because the present humidity is above 80%. Try turning the humidity setting down and let the dehumidifier run for a while. Once the dehumidifier lowers the humidity in the room this level will go lower. If this persists after running for a while you will need to contact LG for service. They back these models with a 5 year warranty. Here is the number to contact them at:
1 (800) 793-8896
Keep me posted. Thaks - Tech101
Jul 25, 2007 | LG LD65EL Dehumidifier
The condensing unit does not run consistently, it clicks on every minute or so.
It sounds like there is an issue with either the controller board or humidity sensor. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Sep 13, 2006 | LG Goldstar LD65EL Dehumidifier
LG LD65EL Dehumidifier Logo
229 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Michael Van Der...
Michael Van Der...
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
