Question about Brother IntelliFAX 2800 Laser Fax
Cannot receive faxes
We cannot receive faxes.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
My fax machine will send a fax, but I can't receive a fax?
The fax machine may be in secure receiving mode. The following is from the User's Manual section on Faxing. downloadcenter samsung com
Receiving in secure receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Activating secure receiving mode
  1. Press btn_fax.png(Fax) on the control panel.
  2. Press Menu until Advanced Fax appear.
  3. Press the left/right arrow until Secure Receive appear and press OK.
  4. Press the left/right arrow until On appear and press OK.
  5. Enter a four-digit password you want to use and press OK.
    You can activate secure receiving mode without setting a password, but cannot protect your faxes.
  6. Re-enter the password to confirm it and press OK.
  7. Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
  1. Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
  2. Press the left/right arrow until Print appear and press OK.
  3. Enter the four-digit password and press OK.
    The machine prints all of the faxes stored in memory.
Deactivating secure receiving mode
  2. Press the left/right arrow until Off appear and press OK.
    The mode is deactivated and the machine prints all faxes stored in memory.
  4. Press Stop/Clear to return to ready mode."
Feb 10, 2015 | Samsung SF-650 Laser Fax/Copier
How do I get my fax machine to receive faxes. my manual is not clear.
First, plug a phone line to the 'Tel' port on the left side. Manual receive fax, pick up handset when fax is ringing and press 'Start' when you hear fax tone.
Auto receive - set the receive mode to 'Fax Only'
Aug 26, 2014 | Brother FAX-575 Plain Paper Thermal
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do you change receiver mode from tel to fax?
If you want to automatically receive faxes, enable automatic answering. If you want to manually receive faxes, then set it to manual receive faxes
Sep 16, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Dec 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Brothers 2800
The machine is probably set to "manual receive." Check the receive mode. In "Manual" mode the machine will ring until the start" button is pressed. Fax mode will allow the machine to receive faxes as will the "Auto" mode which will allow both faxes and telephone calls automatically.
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
