Question about Toshiba PDR-3330 Digital Camera
PNY 2GB memory card
Can the Toshiba PDR-3330 take this size memory card. I put the card in and a message comes across the viewing area indicating I can't use this card. Do I need to format the memory card?
  • precchar Aug 16, 2008
    I have the same problem. need an answer. thanks Precchar@worldnet.att.net
  • nwabuezeogbo Jan 29, 2014
    I have toshiba camera pdr 3330,when i insert SD memory card of 2GB. It will show : This card cannot be use.
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Hope this helps! -Kim
Posted on Dec 26, 2008
I have a new HP computer with Windows 7. Someone gave me a PNY 2GB memory drive with photos I would like to download. Where do I put the memory drive?
that all depends on the model of your laptop, most current laptops have a slot for a standard sd card, if this is the case you will need a micro sd adapter.
if you dont have a port for an sd card you have 2 options, first you can buy a usb memory card reader (making sure it takes micro sd cards before you purchase) or, most mobile phones take the micro sd card so you can put it in your phone and either plug it into your laptop using a usb cable and try getting them that way, or if you can view the photos on your phone, bluetooth/email them across.
Aug 08, 2011 | PNY 2GB microSD Memory Card
I have a Toshiba $GB SDHC Memory Card. I put it in the camera and camera says card is locked. I have slid the yellow lock button and it does not unlock. I also have PNY OPTIMA that has the same problem....
Your main problem is that you are trying to use a 4GB SDHC card in an approximately 8 year old camera which was only designed to accept a maximum 512MB SD card and which only worked reliably with 256MB SD cards. When your camera was designed, 128MB cards were the largest size available and so hardware testing only went up that far.
SDHC cards use a different memory structure to SD cards and older devices cannot use them even though they will fit in the slot. As it's a hardware limitation there is no firmware update option.
Your only fix is to obtain the correct type and capacity of SD card or to replace your camera with one which accepts SDHC cards.
I hope you manage to use this information to fix your problem or at least that it assists you to choose your next course of action. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 02, 2010 | Toshiba PDR-3330 Digital Camera
2gb sd card wont format this is a toshiba pdr-3300
Hi, is it an SD card of normal size? if so there's a little switch on the side which says protect, move this the other way to enable Formatting..
Thanks Mark
May 03, 2010 | Toshiba PDR-3300 Digital Camera
PNY 2GB, Download computer stuff to the memory card?
simply copy stuff and paste them after opening ur card.
vote if find useful
Feb 20, 2010 | PNY 2GB microSD Memory Card
Won't store max amount of memory
I tried copying music to my PNY 2GB, too, and it stopped accepting after about 720 MB. I deleted all the music I had on it, created half a dozen new folders, renamed them, then put as much music as I wanted on the SD. I haven't tested it on my phone yet but at least it let me copy all the music I wanted.
Apr 14, 2009 | PNY 2GB microSD Memory Card
Lost memory card
Why can't you use a different card? Just put it in and format the new card in the camera.
Rob
Mar 11, 2009 | Toshiba PDR-3330 Digital Camera
Misplaced USB Cable for Toshiba PDR-3330
The USB cable for cameras is easily availalbe at most computer or camera stores. You can take your camera along just to make sure one end fits properly to your camera.
The USB cable would have mini connector on one side and a standard male connector on the other side. (cost around $7~10)
Please rate our solution and thanks for using FixYa!
Mar 05, 2009 | Toshiba PDR-3330 Digital Camera
PNY 2GB SD Card will only hold approx. 350 photos
Depends on the size of each file ( picture). If your shooting a large formate then it could ( that's all you can get on it.
Jun 02, 2017 | PNY 2GB microSD Memory Card
What kind of SC memory card do I need to get for a Toshiba PDR-3330 digital still camera?
Aug 22, 2008 | Toshiba PDR-3330 Digital Camera
Toshiba PDR-3330 Digital Camera Logo
160 people viewed this question
Top Toshiba Cameras Experts
john milligan
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
