Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Default Color Settings
While the C351 is fantastic, we have over 1million copies to print and outsourced to a local printer. The local printer is having issue with our color defaults against his own. I know there is an acronym used to describe the standard color or the default color that is used. Can you tell me what the "default color scheme" (for the lack of a better explanation) is for the Konica Minolta C351?
Please and thank you.
  • 167 Answers
If your C351 does NOT have a Fiery it will not use a scheme (profile). With a Fiery you can specify different simulation methods where it will alter the colour based on these settings.
Without this option you are just using a straight through colour process and is really based on the actual copier itself.
It sounds like he is hoping to select the same profile to give him a better starting point.
Though you may love the colour on this device, without the Fiery option it will not match or run under and "Printing Industry Standards".
Your local printer is going to have to do some serious colour tweaking/management and you should be prepared to pay for this.
Posted on Jul 18, 2008
I just installed new printer cart light magenta & magenta the self diagnostic shows them as loaded and 100 %. The print quality pattern does not print any color for either of them? No error codes?? I have...
printers will only print black and white unless you change the print settings to be color
before you go to print find the printer settings or options and make the default setting color
that way it will print exactly what is sent from the computer to the printer
Feb 07, 2016 | HP Photosmart C6200 C6280 Inkjet...
My xerox 6015 will print documents that I have previously printed even tho I am not requesting it to be printed. Nothing is in the print queue to cancel. what is wrong with it?
I assuming you mean you get 2 prints when you only asked for one. Looks like the driver default settings are set to 2 copies.
If you can use the copy facility and print one copy that sort of eliminates the printer. The problem must be further up stream towards the computer sending the print.
You also. If he like to remove the print driver and reinstall it, the default must always be set to 1 copy.
Feb 21, 2015 | Xerox Workcentre 6015/Ni Color Laser...
C351 konica does not print
does it copy??? try different file different program pdf, web page does it print the demo page does it print the counter page????
Apr 29, 2014 | Konica Minolta bizhub C351 All-In-One...
Dots in print c351
what color and copy to or both print and copy
Feb 02, 2014 | Konica Minolta bizhub C351 All-In-One...
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
I am trying to set the copier to black and white as default. I do not find in the manual where to change the settings.
1. Select black on the main copy screen. 2. Select the Utilities/counter button. 3. Select [DETAILS]. 4. Select [2. USER SETTING]. 5. Select [3 Initial settings]. 6. Select [Current Settings]. 7. Return to the main screen.
ftp://207.18.56.26/software/BPG/UserbizhubC351CopyOperFW_G4.pdf
page 12-21
Feb 21, 2011 | Konica Minolta bizhub C351 All-In-One...
Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
Jun 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
No red color printing
Possible nozzle blockage, usually solved by physically squirting cleaning fluid into nozzle and letting soak for a while.
Printers are so cheap nowadays perhaps it might be worthwhile investing in something new!
May 27, 2009 | Office Equipment & Supplies
Printer not printing
try a test page, first, please..computer disconnected from printer..
and go get fresh set of printer drivers here
Mar 17, 2008 | Lexmark JetPrinter Z22 Color InkJet
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
230 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
