Question about Symbol MC70
How to reset MC70 using touch screen
Does anybody know how to reset the MC70 device without using the yellow hardware button? Is there a way to do that using the touch-screen? Thank you.
No,
Not using the touch screen.
But you can reboot from the POWER Button
By holding it in for 5 Secounds, ( this is a warm reboot)
By holding the power button plus the 1and the 9 buttonat the same time is a cold boot. This is a better way...
Hope this helps you!!!
Posted on Aug 08, 2008
It is working ok but the screen is too bright, without adjust Is it a hardware or software problem? thanks
You should be able to adjust it using Tools - Brightness. If you can't it is more likely a software glitch, as long as all the other touch controls on the screen work.
You can update the software here.
http://www8.garmin.com/support/collection.jsp?product=010-00782-20
You can also do two types of reset.
How to Reset a Garmin 1350 by Kefa Olang, Demand Media Whether you're on a local or national business trip, a Garmin Nuvi 1350 GPS can help you find your way around. However, if the device is not functioning as expected, performing a reset is a troubleshooting step that can solve common problems. A soft reset reboots the GPS's hardware without deleting saved data, but a master reset clears saved data and settings to restore the device to the factory state.
Step 1 Press and hold the "Power" button for a few seconds to reset your Garmin Nuvi 1350 if it's not performing as expected. This soft reset reboots the device's hardware without deleting saved files.
Step 2 Turn off the Garmin Nuvi 1350 if you're still experiencing problems, and then disconnect it from a power outlet, if it's connected to one.
Step 2
Touch and hold the lower-right corner of the screen while powering on the device. Release the power button when the screen turns on, but keep pressing down on the screen. Step 4 Touch "Yes" when the "Do you really want to erase all user data?" message appears on the screen. If the text is in another language other than English, touch the button on the right to confirm your selection.
Step 5 Wait for the GPS to reset automatically, and then follow the on-screen guided prompts to reconfigure it.
Jan 15, 2016 | Garmin nuvi 1350 Car GPS Receiver
How can i reset my symbol windows mobile mc7090
did you try this?
  1. Performing a factory reset using phone buttons
    1. Turn the power off.
    2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button. Release the VOLUME DOWN button when you see an icon on the screen.
    3. Then press the following hardware buttons in sequence: VOLUME UP > VOLUME DOWN > POWER > VOLUME DOWN.
Feb 12, 2015 | Symbol MC70 Handheld Mobile Computer (P/N...
How do I get my Iphone touch screen to respond if resetting it is not working?
A nonresponsive IPod touch touch screen can usually be resolved by updating to the latest IOS version. If the device has already been updated, the client would then want to restore the IPod touch to the original factory settings. Should restoring the device and the completion of basic troubleshooting http://support.apple.com/kb/ts1827 fail to resolve the issue, the problem is most likely hardware related. Apple strongly discourages end-users from performing hardware replacement on their devices.
I would suggest calling 1-800-myapple to determine whether this device is under warranty or not.
Hint: If Apple 2nd level phone support were to learn that the malfunctioning device was causing any type of electrical shock when handled, they have a standing policy to replace the device immediately. This is replacement policy is done for legal purposes and is mostly done without question; however, if this is regarding an older device, the client may need push for the replacement.
Jun 13, 2014 | Apple iPhone Smartphone
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
How can i make my cursor respond using the inbuilt touch . it stopped and i have to use mouse
You have to reload the software and the drivers for the touch pad. Often the name of the drivers and the program that runs the touch screen may not seem apparent. If you have the disks that came with the computer, start with the drivers and utilities disk and re-install all driver files. That should get the hardware listed. you should also check your device manager (start button, right click computer, click properties, click on hardware tab and then click on device manager) for any yellow or red icons. The device manager will show you on a tree, all the hardware working on your computer.
Apr 10, 2013 | Dell Vostro 1015 Laptop
Hello i'd like to know how to do a hard reset for the motorola mb611
Reset Motorola Cliq 2 using hardware buttons
  • Make sure your phone is turned off
  • Press "x" key from keyboard and then press "Power" button
  • Release the "x" key when a "Triangle!/Android" screen appears
  • To view recovery menu press "@" key
  • Choose "wipe data / factory reset" using navigation keys (left/right), press "Enter" key to select
  • Choose "reboot system now" and press "Enter" to select and wait for the device to reboot and reset Cliq 2
Mar 09, 2011 | HTC Touch Cellular Phone
How can i download MC70 OS? So how can i find? Have anybody know download link? Thanks.
support.symbol.com
if you need assistance please let me know, unfortunately without a motorola support agreement its not a free download.
kim ganoe
kganoe@datexcorp.com
Oct 15, 2009 | Symbol MC70
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
API call to enable WiFi freezes screen
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Jul 15, 2008 | Symbol MC70
Symbol MC70 Logo
2,392 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
