Question about Haier hwr10xc6 Air Conditioner
Doesn't blow hard anymore
Had for about three weeks and it won't blow much cold air out anymore...sounds different.
Cleaned air filter..
Do I have to drain it or something?
    Problem Solver:
  • 7 Answers
First make sure unit is correct for the size of room. You may have to mount it permanently so that it's tilted so it drains out the window. Check freeon level.
Posted on Aug 07, 2008
Fix vapor lock
Hi, This sounds like the fuel pump needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | Ford Crown Victoria Cars & Trucks
My Everstar portable AC unit will not blow cool air. It won't dehumidify either as the water chamber has nothing in it where before it would fill up every few hrs. Filters were cleaned, is this just a...
The unit needs to be disassembled and cleaned at least every three to six months. The (squirel cage) blower needs to cleaned at least once a year. I cut away the plastic slots at the bottom of the unit with a tinsnips or a pair of dykes, and use a professional fin/coil cleaner brush to clean the condenser coil every three months. This unit should have two filters, one for the evaperator coil, and the other for the condenser coil, but it doesn't. You would be surprised at how much grime forms on the plastic plower.
If you don't clean the condensor coil on a regular basis, headpressure will increase. This will greatly shorten the life of the compressor.
May 27, 2012 | Heating & Cooling
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
My ac is cold and is basically fine. but the problem is that it doesnt blow hard. it sounds like it is but you barley feel anything. what do i need to replace so it blows hard?
For this issue, have the evaporator cooling unit cleaned. The reason why it doesn't blow hard is the dust and dirt are covering the evaporator cooling unit. The dirt and dust are also very harmful to the cooling unit. Have it cleaned and you will see the difference. Hope this helps.
Jul 11, 2011 | 1987 Nissan 300ZX
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
Transmission shifting hard and heater blowing cold air when idlin
heater sounds like the coolant level is low,transmission sounds like a shift solenoid sticking
Jan 31, 2010 | 2002 Oldsmobile Silhouette
The air conditioning isn't blowing cold air anymore. It takes a while for it to get Cold, it blows cool air but not cold.
My name is Ron,and I have one solution,Sounds like you need some freon added,if that doesn`t fix ya ,the ac compressor could be weak,or blockage in ac system,or vent door not opening,or opening slowly,and not all the way...hope this helps,roniecon@gmail.com
Jul 19, 2009 | 1996 Ford Explorer
My frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
May 25, 2009 | Frigidaire FAC084N7A Air Conditioner
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Haier hwr10xc6 Air Conditioner Logo
94 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
