MAYTAG
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective
touch pad or membrane
Replace touch
pad or membrane (usually the touch pad)*
F1
Watchdog on
board
Replace touch
pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay
board (if present) or bad oven temperature sensor
F3 or F4
Open or shorted
Replace oven
temperature sensor
F5
Hardware
and watchdog circuits disagree
Replace clock
F6
Missing AC
signal
Check for
proper voltage
F7
Function key
shorted or stuck button
Replace touch
pad or clock assembly (also called the ERC) or un-stick
button
F8
Analog/Digital
supervisory
Replace clock
F9
Door latch
supervisory
Check door
lock circuit or replace clock assembly (also called the
ERC)
F0
Function key
stuck
Replace touch
* Here is a simple test that you can
do to determine whether the clock or the touchpad are defective
when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control,
or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will
be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power
is turned back on. Replace any covers removed to gain access to
the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault,
replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock
control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or
making this repair please contact a qualified appliance repair technician.
