I replaced my fan motor in my furance and i dont think it is turning fast enough. is there any way to check that out?
  • 41 Answers
Ch the data on the motor compair it to the old one also many are multi speed and can be rewired simply by moving the wire plug position dan
Posted on Jul 18, 2008
What run capacitor will work on dayton fan motor model # 2LY97A
Over heating and like most new product these days throwaway planned obsolescence and made to fail
Feb 10, 2015 | Dayton Dryers
97 Honda Prelude, when using the A/C the car overheats when in stop and go traffic or stopped. If I go 50 mph or more the car is fine with the A/C on. What part do you think needs to be replaced
is the cooling fan working with and without the a/c on.this could be the problem and is it spinning fast enough.if its starting to seize up it won`t be turning at a fast speed like it should.with the a/c on it puts a load on the motor that causes it to work harder thus run hotter.another thing to check is the rad flow as if its not flowing enough coolant it can cause this as well.have you changed the thermostat as if its not working properly it could be not opening as it should again causing the motor to run hotter.
Jul 17, 2011 | 1997 Honda Prelude
When i turn a/c on. the motor barely spins. it wont even spin fast enough for the thermostat to kick in.
mcdevito75 here, Sounds like the fan motor is shot, Check with your local a/c repair shop or replace the unit.
Jun 21, 2010 | Frigidaire FAH125N2T Air Conditioner
I changed my fan motor and squirl cage blower hooked all wires back like they were fan is not turning fast so the compresser is heating up. the old motor the motor mounts went out that why i changed it
Did you replace the capacitor, if not, is it the same mfd and volts for the new motor?
Anytime you replace a motor you should replace the capacitor they don't last as long as they used to and they are inexpensive, a couple of bucks.
If the capacitor is good then most new motors now have the wiring connectiions on the motor, you might check to see if the new motor wires the same as the old motor.
Oct 07, 2009 | Dometic Rooftop RV Air Conditioner
The coil in my byrant furance is freezeing up , my ac has been running for hours and i noticed that the house was not cooling down. when i checked the furance i noticed ice on the outside of the coil above...
Low on refirgerant, or dirty coil, or it was run on a cold night. Either way, the only way to take care of it is to start by running the fan only, and shutting the cooling off. This will melt the ice on the coils. It is going to make a mess. Have the unit serviced if it is not dirty, if it is dirty clean it with an approved cleaner. Your local hvac repair shop should be able to recommend a good cleaner.
Jun 09, 2009 | Heating & Cooling
My air conditioner fan is broken, i think.
Fan may need a new start capacitor. It appears or sounds like the motor is not getting the puwe it needs I don'y know what "not fast enough" is to youm but those fans really dont turn very fast, There should be two fuses in a box near the outside unit/ One can bbe bad causing low power to unit. To ck the, There should be something on the fuaw to indicate it's blown. WARNING!! dO NOT TRY REMOVING WITHOUT TURNING OFF ALL POWER AT THE MAIN HOUSE SUPPLY CIRCUIT BREAKER, hIGH VOLTAGE CAN AND WILL, GIVEN THE CHANCE. iF IN DOUBT, CLL OUT A QUALIFIED SERVICE COMPANY.
May 25, 2009 | Goodman CKL24AR24 Air Conditioner
FAN MOTOR CONTINUES RUNNING AFTER HEATING CYCLE IS COMPLETED BLOW
Check the thermostat. Make sure it is set for AUTO fan not ON fan. If that is OK replace the fan relay.
Apr 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
94 honda is overheating
I dont think the transmission has anything to do with your overheating problem...Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Mar 21, 2009 | 1994 Honda Civic
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
