Question about Zenith DVP615 Portable DVD Player
AV Out cable for portable Zenith (DVP-615) dvd.
I lost the av out cable to plug into TV cable (RCA). Model DVP-615. Where can i find it?
I lost the AV cord to my Zenith DVP-615 portable DVD player too. I bought a standard RCA AV but it did not work. I found my cord so I was able to compare.
The standard RCA AV cable has a 4-part mini-plug. The tip is white, next is yellow, next is ground and the base is red. For the Zenith DVP-615, the tip is yellow, next is white, next is red and the base is ground.I never found where to purchase a replacement but perhaps this will help someone make their own.
Posted on Jan 14, 2012
SOURCE: No picture but has sound
To fix this eject the disc and hit the stop button for 5 seconds to reset the unit.
Posted on Dec 31, 2006
SOURCE: GPX portable dvd player does not play on bigger tv with rca cable
You have to buy the $15 video cable from GPX. I tried several differant cables including RCA to S Video as a last resort. They say theirs is propritary and I now believe it!!!
Posted on Mar 12, 2009
  • 303 Answers
SOURCE: Need a new ac adapter for a DVP615 portable dvd/cd player (Zenith
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord ZENITH DVP615
Posted on Mar 29, 2009
SOURCE: I have a Nortech Media EDVKIT006 Portable DVD
sorry cant solve ur prob but maybe u can help w/mine. i dont know how to get them playng together
Posted on May 22, 2009
  • 4 Answers
SOURCE: INeed av cable for Trutech 7? Dual-Screen Portable DVD Player
Okay, I just had to replace both the DC power and a/v cable for this Trutech DVD player and here is the solution. The a/v cable is a 4 pole 3.5mm cable, which I found here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html I went to Radio Shack and bought the coax style DC power plug ends which were size B and soldered new ends onto the old power cable, tip to tip, sleeve to sleeve: http://www.radioshack.com/product/index.jsp?productId=2102598
Posted on Dec 14, 2009
Low volume output signal.
Have you tried a different cable.
Jul 08, 2017 | Sony DVP-NS57P
Can I connect my to iPod Classic to watch video on Sony DVP-FX970 Portable DVD player? If so, what connection do I need?
The DVP-FX970 uses a composite (3xRCA) to mini-AV (2x mini-plugs) reducing cable. This is Sony part 9-885-103-56 and was included with the DVD player in the original packaging. See https://sony.encompass.com/item/7054170/Sony/9-885-103-56/Av_Cable_(010-0001-206) . Other vendors may also have the cable. You will also need an RCA (3xF) coupler, see http://www.cablestogo.com/product/40647/composite-video-stereo-audio-f-f-coupler-taa-compliant for one option. Connect the composite end of the above cable to one side of the coupler and the other side to the DVD player. Next connect the appropriate iPod Classic video dock, https://www.apple.com/shop/product/MC748AM/A/apple-composite-av-cable , to the other side of the coupler and the iPod Classic. Now, turn on everything and press the Input Select button for the DVD player multiple times until the current input is 'Line In'.
I hope this helps.
Jun 24, 2017 | Televison & Video
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
I have lost colour in my DVD Player, It's showing black and white illustration. How to fix it.
U hook it up wih a AV RCA R,Y,W cable change the cable or u used a HDMI cable,change another HDMI cable to another tv HDMI hub.
Jan 29, 2011 | Sony DVP-NS508P/S DVD Player
What kind of AV cable is used for the Kawasaki PVS10921 Portable DVD Player? I have the player itself, but lost the AV cable to connect the player to my TV, and I've been unsuccessful in my attempts to...
The cable supplied with the player splits the audio feed from a single audio jack to dual RCA jacks for connection to a standard VCR or TV. The video appears to be a straight RCA to RCA type connection where a standard cable can be used.
See the users manual here:
http://www.1800customersupport.com/productdocuments/PVS10921%20Product%20Manual.pdf
Dan
Aug 26, 2010 | kawasaki PVS-10921 Portable DVD Player
What type of cord I need to connect my TF-DVD7005 Portable DVD Player to a tv?
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 04, 2010 | Coby TF-DVD7005 Portable DVD Player
Can a Sony DVP-NS710H work with a non-HDTV? I have an older TV model (2001) and need a new DVD player. I am looking at this Sony model and would like to purchase.
yes, you must have at your tv one of this plugs: Connector Type Sony DVP-NS710H 1 x Composite video output ( RCA phono ) - Rear , 1 x HDMI output ( 19 pin HDMI Type A ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x Audio line-out ( RCA phono x 2 ) - Rear , 1 x Digital audio output (coaxial) ( RCA phono ) - Rear on your tv the connector is input.
Feb 14, 2010 | Televison & Video
Zenith DVP615 Portable DVD Player Logo
414 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
