Sharp Copier AR-M350N+
Network error (CE-00)
  • 1 more comment
  • hiplainsgirl Jul 16, 2008
    Hi, I had them recycle power on the copier and the network error was gone on power up.
    It is a networked copier\printer
  • grie12345678 Jan 13, 2009
    sharp MX-2700network error CE-00
    want to send to server
The machine is set up for networking. You may need a tech to go into the simulation mode to turn that off.
Posted on Jul 16, 2008
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M350N memory?
AR-M350N may be have 16 Mbyte of internal memory.
You could expand it until 256 Megabyte.
I attacched to this post an image that describe compatible expand memory.
Nov 03, 2009 | Sharp AR-5320 Black and White Copier
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
Jun 02, 2009 | Sharp AR-M450N Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
1,502 people viewed this question
k24674
jasbo
jasbo
