Question about Targus AMW15US
Targus mous I need to install the mouse on a new computer and I no longer have the disk
    Scholar:
  • 46 Answers
Hi
You should be able to download the necessary software from here. If you give me the exact model of your mouse I may be able to locate it more specifically.
Hope this is of use.
Philip
Posted on Jul 15, 2008
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
Targus mouse not working
I checked the Targus website (http://www.targus.com/us/default.asp) for any other useful information. Use the "support" option at the website for a good troubleshooting guide for your particular mouse. Is this a new mouse? The mouse you have uses the native windows drivers and should be auto-recognized by XP. Have you kept your XP updates current? My concern is why XP could not install the software drivers needed(You would have gotten some type of an error message). Check the "details" link shown with the error message.That should point you in the right direction---rick
Sep 10, 2009 | Targus Mini Kaleidoscope (AMU0503US) Mouse
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Not able to install and use AMU02EU in vista
Vista says something along the lines of it can't find driver?
I had that happen with my new Targus wireless rechargable mouse.
Look in device manager, if it is listed as an UNKOWN DEVICE, you need to manually install driver as HID-compliant mouse.
Details:
Go to >Control Panel > System Select Device Manager from lefthand list.
There should be an "Unkown Device" in the list. To be sure, expand Mice and other pointing devices and see if your device is already there. Better yet, unplug mouse's receiver and the unkown device should go away.
Right click on the unknown device, and choose Update Driver Software... select Browse my computer for driver software then Let me pick from a list of device drivers on my computer then you need to find Human Interface Devices and subcategory HID-compliant mouse.
Vista tends to try and install these devices as USB mice when they should be HID.
Apr 22, 2009 | Targus Wireless Optical Notebook Mouse...
Targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
Targus AMW25 Mouse Only goes Lower Left to Upper Right! HELP!
bad mouse yes buy microsoft ones way better quilty and suport ok
Feb 10, 2008 | Targus PAWM001U Mouse
Targus AMW15US Logo
311 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
