Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Kenmore side by side
Fridge stopped working no water in pan
    Genius:
  • 1,122 Answers
Need more info ,you mean it stopped and the compressor in not running?
Posted on Jul 15, 2008
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
A lot of water leaking
You probably have a clogged drain line. Unplug the fridge for 24-48 hours with a towel by the drip pan for a simple fix.
Jan 22, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side refrigerator, model number 106.53632300 that is leaking water and coming out onto the floor. The drain pan (I'm assuming that's what it is) underneath the fridge is full of...
Sorry to read about your problem, I hope this helps you out.
i would turn off water to the unit, if its hooked up.see if it stops.. if not you lost the unit and it is melting
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Fridge: 44103 side by side: I keep finding a
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
We have had water leaking on the floor for 3 weeks now. We have checked Ice Maker, water depenser, and even disconnected all sources of water to refrigerator. The refrigerator is a Kenmore.
Check the pan on the bottom of the fridg. the hose could of slipped out, this runs from the freezer section to the pan, when it goes into defrost water goes to the pan
Nov 11, 2008 | Kenmore 50522 / 50524 Side by Side...
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
