Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice Dispenser does not work.
Kscs25inss water dispenser works, ice dispenser does not.
Motor hums when the dispenser is pressed.
  • ralanc Jul 25, 2008
    Thanks for the input.
    Kids put bottled coke in freezer on top of ice.
    This caused some ice melt, and the water ran down into the auger motor. When it refroze, it locked the motor down.
    Removed, thawed, and reinstalled the motor. Works like new.
    Bottom line is not to place anything in the ice bin.
    Alan
Agree, but add most common problem is tray not installed(inserted ) correctly not seated Above solution is good cause most common reason is ice buildup preventing proper seating So after cleaning make certain it goes all the way in and it should sort of SNAP or click into place AND SHOULD BE LOCKED IN If is pulls right out, then u are n ot getting it in properly You should have to press a button or lever to remove it also check that metal wire arm is DOWN to make ice lastly the corkscrew thing must turn to dispense ice, you should hear it turn and stir the ice If it makes noise(hum and ice noise) then the chute thru the door is just clogged good luck
Posted on Jul 16, 2008
  • 4 Answers
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Posted on Jul 15, 2008
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Jun 24, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser is not working
a possibility is that the water tank has frozen up in the refrig side. what i do is remove the middle crisper drawer and put a hair dryer blowing on the water tank in the back. do this for about 5 mins then start trying to get water out of the disp and it will clear it out. peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
226 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
