Need instructions to hook-up to old antenna TV
  • bobmar125 Jul 15, 2008
    I Have an RF Generator I have a cable Box My old TV has a 300 ohm connector to a coaxial cable ??
  • 2,071 Answers
  • LORETO LACARON
    LORETO LACARON Jul 16, 2008
    First you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
    cable
    coax output or if that cable have video/audio ouput is going to INPUT
    >to combo VCR / DVD player video / audio output is going to INPUT
    > to TV,.that's the time you can record and playback;
    click below for more information in hooking up:
    DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
    Good luck ,and Thank you in advance:
  • 19,396 Answers
What equipment do you have?
Posted on Jul 15, 2008
  • 3 more comments
  • Ginko
    Ginko Jul 15, 2008
    Generally there is an Aerial in or Ant in (analog) socket at the back of the dvd.
    Aerial should be connected to DVD then a plug indicated as Aerial out or TV out must carry a cable running from dvd to TV aerial in.
    I can be more specific if you provide model details.
  • Ginko
    Ginko Jul 15, 2008
    From Connect a DVD Recorder to a TV:"If you have an older TV that only accepts RF (Coaxial) input, then you
    would connect the RF output (a coaxial cable) from your TV source (in
    my case a Cable Box) to the RF input on the DVD Recorder. Then connect
    the RF output from the DVD Recorder to the RF input on the TV. This is
    the most basic (and lowest quality) option for connecting a DVD
    Recorder to any TV."
  • Ginko
    Ginko Jul 15, 2008
  • Ginko
    Ginko Jul 15, 2008
    This is quit simple, do the same
  • Ginko
    Ginko Jul 15, 2008
    Look at picture above, you do not have an rf modulater, so, where is written RF modulator you put your DVD, and connect only Coaxial cable, or coaxial and scart, it is the simplest possible configuration.
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
How do I attach a flat leaf antenna to an older Phillips TV
The old style TV's need a converter box. You cannot just hook up an antenna directly to the TV. The TV signal in the air is now digital. Your old style TV has an analogue TV station tuner. The converter box transforms the digital signal into a usable analogue signal. Just do a online search to find out any information that you need.
Oct 18, 2015 | Televison & Video
I have a 32" Coby with built in vcr can i hook tv to it with an antenna
if the TV is a newer digital model, installing a regular antenna should give you local stations to watch.
Oct 10, 2014 | Coby TFDVD3297 32"" TV/DVD Combo"
I cant connect my dtvpal converter,my indoor old antenna, to an old 19 portable tv? please help
Since they began broadcasting digital you will need to get a converter from Radio Shack. Might be easier to just get a flat panel TV.
Sep 20, 2014 | Televison & Video
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
    Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
    Apr 20, 2012 | Pioneer Audio Players & Recorders
    Antenna hook up
    Depending on they type of connection you have, you may need an adapter. For specific instructions on how to hook up the box to your TV, click here: http://www.dtvtransition.org/downloads/converter_qsg.pdf
    Jun 17, 2008 | Televison & Video
    Hook up old tv antenna to converter box
    how do you hook up a tv with just screws to a converter?
    May 27, 2008 | Televison & Video
    Televison & Video Logo
    49 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
