Yes you will, good news samsung is one of the easy ones,, first unplug the unit, then take two screws out of top on the back,, push the top cover back and off,,,,,,, then take the screws out of the top of the control panel tilt it forward then up,, you will now see more screws remove these also, open the door and look at the bottom of the gasket, you will see a spring on a wire ring, take a small flat head and remove the ring,, fold the gasket back into the unit,, then moving back to the top push in the tabs and the front should tilt forward,, you will need to reach down inside the unit and unplug the door lock then the front panel can be took off,, take the weights off be carefull they are heavy to be small, then locate the back clamp that holds the gasket and remove it,, install the new one, just like the old one came off,,MAKE SURE THE GASKET SITS IN THE GROVE THEN INSTALL THE CLAMP AND WEIGHTS, THEN INSTALL THE REST OF THE PARTS IN THE SAME ORDER YOU TOOK THEM OFF,, when you are putting the outside spring back on it will be kinda hard,, do not use any tools as you will tear the new gasket,, but make sure it sits in the grove
Testimonial: "Just what I needed! Thanks."
