Question about Hotpoint Dishwashers
Hotpoint dishwasher fdw60
After machine has been programed and switched on, goes to wash and after about 3-5 minutes machine stops and eco and fast lights come on can you help
The fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
Posted on Jul 16, 2008
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
FDW60
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Please don't forget to rate me!
Jul 12, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Eco and Fast lights flashing
Don't forget to rate me!
Jul 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint FDW60 problem
hi
you will proberbly find that you have a control module fault.
connection from you heater and or thermostats faulty.
if your heater was open curcuit it would flash fault codes.
Apr 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW 60 Float and Filter Clean problem
Blockage in internal pipework causing water not to circulate fast enough to stop switch activating. Regards Advisor
Aug 17, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
97 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
