Question about Dell Inspiron 5160 Notebook
Integrated 10/100 nic card problems
The nic card in my 5160 doesn't stay connected. I keep getting the meaage "A Network cable is unplugged" If I wiggle it a bit it will connect, but then go back out. I tried several differnt CAT5E cables with the same result, so I feel I pretty much ruled out a bad cable. I have a wireless USB adaptor that I can use at home, but we don't have wireless at the office. Can the card be replaced with a combo 10/100 wireless?
  • KenInCT Jul 15, 2008
    Where is the best place to get the wireless/combo card?
  • KenInCT Jul 16, 2008
    Thanks. One other question:are these wireless/combo cards normally USB adapter types or will it actually physically replace the bad 10/100 in my 5160?
    Genius:
  • 2,028 Answers
The card has developed a loose connector, it's just worn, it happens and is fairly common with these, and there nothing you can do about it, other than replace the card, and yes you can replace it with a 10/100 wireless/combo. Just remember to uninstall the drivers for the old card prior to installing the new card in order to keep from having a conflict. That is, if there are drivers, a majority of these cards are plug and play. With the wireless/combo there will be drivers.
Posted on Jul 15, 2008
  • Ryan Rogers
    Ryan Rogers Jul 15, 2008
    Walmart has a good selection of wireless cards, but I'm not sure they carry the combo card. Bestbuy does, but they will be more expensive. If you don't mind waiting a couple of days, you can also check online and probably get the best deal, try pricewatch.com
  • Ryan Rogers
    Ryan Rogers Jul 16, 2008
    The ones I've been talking about are either a bus or usb port card. If you want to replace the internal card I suggest pulling the card to get the make and model, then check Ebay. I get all my internal cards from Ebay. I find that there are generally several good working cards that have been pulled from nonworking machines at very reasonable prices.
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Internet connection failed
Well the first thing to do is try to isolate the problem. Before we start make sure the 1st PC will give the same network cable unplugged error if it too is unplugged. Once that is done start by unplugging the network cables from the PCs and switch them. Does the problem stay with the 2nd PC or does it move to the 1st? If it stays with the 2nd PC then the problem is with the PC network card or more likely its configuration. The network card should be configured exactly as the 1st one, probably to obtain the IP and DNS addresses automatically. If you need help with this let us know the operating system you are using. If the problem moves to the 1st PC that indicates the problem is with the cable and/or the router. Now switch the cables at the router end, if the problem stays on the 1st PC then that network cable is your problem. It could be a ?cross-over cable or simply damaged. If it doesn?t move then the problem would be in your router. Either that router port is bad (try using another port) or the one port that works is configured uniquely. You?ll need to take a look at how your router ports are configured and look for the differences. Let us know what you find and we?ll go from there.
Jul 30, 2007 | Linksys Instant Broadband EtherFast...
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
What is NIC?
Network Interface Card.It allows you to connect to a network.Most common cards are PCI 10/100 ethernet network cards.NICs can be integrated into a motherboard which knows as an Onboard card.
Aug 12, 2010 | LaCie Computers & Internet
Looking for replacement card for Nic integrated PS2, Video and Ether
The server could not connect to the network. The network and its cables are all okay.
Feb 02, 2010 | HP Compaq ProLiant DL380 G2 Server
Fixable problem or motherboard going out?
Make sure that modem port is working. Check modem on other PC.
Use different LAN cable.
I suspect NIC failre... you can installa addtional a PCI Ethernet Card and disable integrated NIC.
Oct 20, 2009 | ASUS P4V8X-MX Motherboard
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Jul 22, 2009 | Dell Latitude E6400 Laptop
NIC hardware failure
Maybe your problem is software related. Maybe a virus changed some settings. I would check all the internet settings and the network card settings. I've seen this happen before. In windows xp click Start/Control Panel/Network Connections. Then right click on your local area connection and Click Properties. Slide the bar down to the TCPIP protocol and highlight it, then click Properties. Make sure you are obtaining the IP Address and DSN Server address automatically. Click the Advanced button and make sure DHCP is enabled.
Dec 23, 2008 | HP Pavilion dv1000 Notebook
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Dell Inspiron 5160 Notebook Logo
Alun Cox
