Not a valve, but a lifter. I will paste procedure below. You judge if you can do it or not. Recommend you replace them all while you're in there. If you let this go, the lifter will wear out the camshaft. Lifters are $22 each, and you have 8 of them. You will also need a new valve cover gasket. Fig. Fig. 6: Remove the spark plug wire separators from the valve cover Fig. Fig. 7: Compress the engine air cleaner-to-valve cover hose clamp with pliers, and slide the clamp back ... Fig. Fig. 8: ... then disconnect the hose from the valve cover
Fig. Fig. 9: Unfasten the valve cover retainers and remove the valve cover-2.0L SOHC engine
Please let me know if you have questions, and thanks for using FixYa.
2.0L Engine
SOHC engine
See Figures 6, 7, 8 and 9
WARNING
Do not use any abrasive grinding discs to remove gasket material. Use a plastic manual gasket scraper to remove the gasket residue. Be careful not to scratch or gouge the aluminum sealing surfaces when cleaning them.
If removing more than one valve lifter (tappet), mark the lifters and their locations as they must be installed in their original bores.
To install:
Make sure the lifter guide plate retainer tabs are towards the rear of the cylinder head, and the lifter guide plate tabs are towards the front of the cylinder head.
Do not use any sealer with a silicone type gasket.
The loud ticking can be bad lifter-bent push rod bad or cracked rocker -or no oil to lifter and or valve would need to pull off valve cover and look at operation of valve train a loose rocker can be tightened down to 0 lash if the problem is a loose rocker --if the valve rocker is oil starved need to flush oil system --if bad /flatten or damaged lifter will need to replace lifter
If your mechanically inclined and have a bunch of metric tools and time, yes you can do this yourself. Valves don't get loose, they wear and springs break and rockers and lifters fail, this is what the ticking sound comes from. You might just have an exhaust leak, that makes a ticking sound as well. I suggest you take it to a garage that will give you an estimate and let them look at it so you can decide if you want to tackle this issue or not and if it is worth keeping the car. If it is just a valve you will have to remove the head and evereything that is connected to the motor so you get to all the bolts and hoses. Once the head has been remove you will have to take it to a mcahine shop and get the valves replaced and the head ground. If you just replace the bad valve without re-grinding the head, the valve will wear out very quickly and you will be right back where you started. Then you will have to replace all the gaskets and hoses and belts.
