While driving home today in my mimi cooper s, I smelt the anti freeze and saw smoke coming from the front and the coolant temp went into the red. I pulled over and within 3o mins the returned to the norma.l
It sounds like the water pump is not working. Google your make and model with the words 'water pump repair' after it, if you want to try repair yourself. Otherwise take it to a mechanic you know and trust
is the cooling fan cutting in ? run the engine whilst stationary with the hood up , give it a little gas 2000revs and wait for the temp gauge to rise ,the cooling fan should be heard cutting in , and off again once cooled the engine temp down ,this may take 10-15 mins but you have to be sure the fan is cutting in or you may cook the engine
this does sound like a head problem (hopefully just the gasket). pulling the head with the exhaust manifold attached is possible but tricky and difficult. risking the bolt and drilling it out if it snaps would be alot easier. I would strongly suggest having the head checked while its off (so you dont rebuild to find that you wasted time and money on a bad head)
well, driving it 30 minutes after it over heated might have cause serious engine damage, warped head, and other bad engine wear, let the engine cool down park it in a level place and check the fluids, if the water has a milky substance in it then you have a bad problem, if the oil is low then check for leaks, check the transmission fluid for proper fluid level and that could stop the hard shifting.
the smoking could be coming from the fluids that leaked out and when they get hot will start smoking, antifreeze residue will smoke for a short time, it might just need to burn off
Had similar problem. The actuator that opens & closes the air blend door quit working. This is easy to see if you remove glove box. The actuator will move when you adjust the temp selector (do this while the heater is running).
could be that you have either a loose connection to the coolant temp sensor or the sensor itself is bad you will find the sensor near the thermostat housing on the intake manifold. p-lease rate this
