Question about Technics Audio Players & Recorders
I WANT TO KNOW THE BEST WAS TO CLEAN A USED DUSTY TECHNICS 1200. DO I NEED A SPECIAL FLUID AND CLOTH? wOULD I NEED TO VACUM THE INSIDE? I JUST GOT THEM FROM A GUY. THEY ARE NOT ABUSED. BUT HE COULD OF KEEP UP BETTER ON THE MAINTENANCE. THANX A MILL
  • OGERMANBEY Jul 15, 2008
    Sorry I was not clear I am refering to the Technics 1200 Turntable.
  • 682 Answers
Vacum is better and after you get out from dust you can apply a lubricant contact cleaner over switches volumes-buttons-sockets(where you insert your jacks)-bring the cleaner from near radio shack.
Posted on Jul 15, 2008
We have lost the special cloth and directions on how to clean the screen on our Samsung flat monitor #50000:1. I think the directions called for using soap and water to clean the screen with the special...
U can u just used a plain white old T-shirt soke it with some water,but u will have a risk of a 50/50 chances u will could have many micro scratches on the tv LCD screen panel itself by just using a plain cotton T-shirt,because cotton fibbers have wolfen wood inside it cells structures.As u used a Micro fibers clothes clean the LCD tv screen are made out of by spacial silk worm cacoon materials.
May 13, 2011 | Samsung P2370HD 23" HD LCD Monitor
Tip
How To Clean Laptop Screen With Household Products?
<p><b>Cloth</b> - Only use a 100%-cotton cloth that is soft and absorbent, either an old T-shirt, sock, or Turkish towel. Make sure you're not using a cotton/polyester blend that contains stiff filaments which can scratch an LCD's surface.<br /> <p><b>Note:</b> Paper towel or facial tissue should never be used because they contain wood fibers, also hazardous to LCDs, and definitely are not how to clean a laptop screen. Also remember to never use a dry cloth on your LCD monitor. Dust particles moved around with even the softest cloth could create scratches.<br /> <p><b>Liquid</b> - The best way to get a really clean laptop screen is to use isopropyl alcohol, containing 91% pure alcohol, with 9% de-ionized water, readily available at any drugstore or supermarket. It's perfectly safe for use on electronic equipment and LCD screens because it evaporates quickly and does not leave a residue. The lesser strength isopropyl alcohol 70% is used primarily for massage and muscle pain.<br /> <p>A 1:1 solution of distilled water and isopropyl alcohol 91% can be used to clean a laptop screen that is not heavily dusty or soiled with greasy fingerprints. Vinegar and distilled water in a 1:1 solution can also be used for light cleaning.<br /> <p>Certain household liquids should never be used on LCD's. These include ammonia and tap or mineral water, which leave permanent white spots and streaks. Household window cleaners should be avoided because they might contain ammonia, or other harmful chemicals which also can cause irreparable damage.<br /> <p>Another caution is to never spray a solution directly onto an LCD. Always spray the liquid on a cloth, only enough to moisten it slightly, and then apply to the screen in gentle, counter-clockwise motions.<br /> <p><b>How To Clean Laptop Screen With Special Cleaners?</b><br /> <p><b>Kits</b> - Micro-fiber cloths and anti-static solutions are packaged together and sold at office supply or electronics stores. The special solution leaves a slight film that protects a clean laptop screen, repels dust and smudges, and keeps it clean longer. The liquid should be sprayed onto the cloth, which only needs to be slightly wet, not dripping, when applied to the screen. There's a slight disadvantage to these kits. Certain solutions cause streaking, so it's best to do a little research before investing in this method.<br /> <p><b>Micro-fiber</b> cloths can be purchased separately and used with isopropyl alcohol 91%, and/or distilled water. Whether using the complete kit or the cloths alone, make sure the packaging designates the product is ''safe for laptops and LCD screens."<br /> <p><b>Anti-Static Cloths</b> - Many computer manufacturers, when asked how to clean a laptop screen, recommend anti-static cloths made specifically for cleaning without liquid of any kind. These cloths are formulated for advanced optical technology and are considered the best way to clean, polish and protect a laptop screen. Even greasy fingerprints can be buffed off using these cloths, readily available at electronics or office supply stores.<br /> <p>Similar cloths are made for cleaning camera or eyeglass lenses, and these can be found at any drugstore, optometrist or camera shop. Anti-static cloths are the quickest and easiest solution when you want the most advanced and easiest method to both protect and clean a laptop screen.<br /> <p>The above options offer a variety of easy and safe ways to care for your LCD monitor. With simple maintenance on a regular basis, a laptop screen will last for many years.<br />
on Mar 14, 2011 | Computers & Internet
Tip
How do I clean my flat-screen monitor?
<p>You don't have to turn the monitor off before cleaning it, but this will help you see the smudges and smears. If your screen is merely dusty, you can wipe gently with a soft, cotton cloth or try a can of compressed air. But if your screen is downright grungy, you might have to resort to some tougher tactics.<br /> <p> <br /> <p>Though some people recommend using Windex, ethyl alcohol and ammonia-based cleaners can yellow your flat-screen or laptop monitor over time, so it is best to avoid such products. You can find an array of commercial products specifically designed to clean LCD screens, but you may prefer to just head to your kitchen and mix up your own solution. Plain old water can do the trick, or you can concoct a solution of vinegar and water or isopropyl alcohol and water.<br /> <p> <br /> <p>Always use a soft cotton cloth, rather than a rag or paper towel to wipe the screen. Some people recommend special electrostatic cloths, like those used to clean eyeglasses treated with anti-glare finish, or even dryer sheets. Apply the cleaning solution to your cloth rather than directly to the screen and wipe in one direction -- from the top of the screen to the bottom.<br /> <p> <br /> <p>One final word of warning, never touch or press on your LCD screen with your fingers as this can cause the pixels to burn out.<br />
on Nov 28, 2010 | Televison & Video
What kind of product should i use to clean my TV screen.
Good luck and do rate the solution plz
I have the first digital rebel and as of lately my images are not as crisp as they used to be. Im having this issue even when I use a tripod...I also use auto focus and the images are not as...
when you take the lens off .. there is a mirror and the CCD array ... those can get dusty or if anyone smokes around the camera then that gets on these parts .. you can dust the mirror and CCD behind with a soft clean camel hair brush but a good cleaning should be done by a pro .. thats a "front surface mirror" .. that is, the mirror surface is not protected by glass the way mirrors normally are .. so it scratches very easy ... there are special techniques for cleaning that must be learned before attempting a deep cleaning .. the back side of the lens also may have a smoky coating that has to be cleaned .. again a pro is best but you can use a lens cleaning cloth and solution .. (dont spray the solution into the lens . only on the cloth .. with every thing clean your camera should be back to like new performance ..
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Tip
How to clean a rear projection tv INSIDE
This is what I did and it worked great-
I have a 60" Phillips bigscreen that has been getting dusty and actually had a spider inside the tv for about 6 yrs. This bothered me a lot until I got the guts to unscrew the back covering (the large dark grey turtle shell type plastic cover). It came off very easily.
1. I made sure the tv was unplugged
2. once inside I could see all components easily
3. I rolled it outside onto my deck
4. I used my leaf blower to instantly remove all the clumps of dust and webs followed by a once over with my swiffer
5. I then used a soft glasses cleaner cloth to fine clean each of the 3 colored lenses
6. a damp soft cloth was used to clean mirror
7. replace the back cover and go! It made a huge difference in picture quality
on Apr 25, 2010 | Audio Players & Recorders
The inside of my powershot a590 viewfinder is really dusty and i need to know how to clean it
microfiber cloth u can find these at costco use them for any optical cleaning TV's, sunglasses and cameras
Sep 02, 2009 | Canon PowerShot A590 IS Digital Camera
Cleaning a touch screen
use micro fibre cloth make it damp not wet and just clean the screen , u can try it dry but cloth needs to be special type micro fibre used to clean LCD 's
pls rate me FIxya for help
Apr 22, 2009 | Nikon COOLPIX S60 Digital Camera
I've got to be honest...(in response to your question)
The need to be cleaned as much as you play them. If you play them on a daily basis, I would suggest cleaning the pitch faders at least once a month. Also, the studio environment is also a factor. Is it a dusty place, or relatively clean?
You can clean the faders out with an air can, and some Deoxit or other contact cleaner. DO NOT USE RUBBING ALCOHOL.
There are 2 was to clean, blow the air can inside the fader, removing any debris, then spraying your contact cleaner, then spray air again.
Or, you can take the turntable apart, take the pitch control apart, and clean the contact fader inside. Desoldering is required for this. But it's a more thorough cleaning.
Helpful tips can be found here: www.djproaudio.com/Help
Or, you can just buy a new fader, and install <-- easiest method!
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Aug 06, 2008 | Technics SL-1210 Turntable
Glass dusty inside
hi,
u can clean the glass using a lint free cloth. not necessary to have little moisture in it.
thanks and regards
agnel
Mar 18, 2008 | HP PSC 2110 All-In-One InkJet Printer
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
