Question about Motorola Mobility RAZR V3m Cellular Phone
Dust behind screen
There seems to be dust behind the screen, I can hardly see anything, is there a way to remove it?
    Problem Solver:
  • 5 Answers
Take it to any cell phone store. Unless you know what you are doing
Posted on Jul 29, 2008
  • Robert Moorman
    Robert Moorman Jul 29, 2008
    Unless you know what you are doing I would suggest you take to any cell phone store or Best buy
My track ball will not scroll down.
hey, I have had that happen a bunch. it seems like dust or lint gets behind the ball. blow really hard on the trackball area or use dust spray.
Oct 12, 2009 | RIM BlackBerry Pearl 8100
TV shuts down due to air flow being blocked
They had some stupid problems with these sets---If you know how to remove the lamp---it is customer replaceable--take it out and examine it. Shut set off first and wait a few minutes for the lamp fan to turn off. Unplug set and locate and remove lamp. Some of these sets had a lamp (it is in a cartridge like a box) that they covered openings on the housing with a screen like material (like window screen). One side of the lamp has a fairly small narrow strip of this and it blocks up with dust from the fan which is trying to keep it cool---if the screen is blocked up you will see it; Do not touch the face of the lamp when you handle it--if you find yours has a screen like material--clean it off with a brush and put it back--the later replacement version of this lamp has a screen that is coarse and does not block up with dust---on a couple of these I removed the blocked up screen material until I could get the newer lamp so the customer could continue to use it--if cleaning the dirt off works you may have to do it from time to time--depends on environment--the fan tends to pull dust and such out of the air and right into the lamp---
I do this for free here so if this does help you give me a vote here. If you have questions or need help contact me here.
Aug 28, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Water marks and dust on the INSIDE of Nokia 6085 LCD screen
Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
Mar 31, 2009 | Nokia 6085 Cellular Phone
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dull colors, dim images
Where did you buy the lamp at? Does it look the same or worse than when the old lamp was in there and working? Is there a big difference or if there wasnt another tv sitting next to it mabe you wouldnt notice? Also you dont need to clean the screen, that could damage it. If you are going to clean anything you will need to clean the mirror behind the screen.
Sep 16, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Sony Ericsson K550
How do i remove the front cover, there is dust behind the screen
Aug 17, 2008 | Sony Ericsson K550i Cellular Phone
Dust behind screen
take off the screen cover (the plastic) with a pin and clean it with a (magic) cloth.
Jul 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Dust behind screen
2 ways. There are two access panels about mid screen on the sides of the cabinet. Or you can take all of the screws out and take the whole screen apart ,all the way down to the lens on the projector. It is up to you. If you are pretty mechanincally inclined then take the whole cabinet apart, as you will be able to clean more of the cabinet. Use a microfiber cloth to clean both the screen and the rear mirror. Hope this helps. I usually clean mine every three months or so.
Jun 27, 2008 | Televison & Video
Inside screen seems to be getting dirty
I had the same problem until I removed the screen and cleaned the front mirror with a static feather duster. First, turn OFF power. Second, remove screws on rear at top and on both sides of the screen. Third, remove speaker grill. Fourth, remove screws on each side of the screen where screen meets the speaker area. Fifth, remove two screws in center area of speaker area under screen. Sixth, lift screen up and away from set housing and use a duster with a two to three extension and GENTLY wipe the noticeable dust layer from the front tilted mirror located behind the screen at bottom of screen. Seventh, do everything in the REVERSE and you're done. If you need to replace the lamp, now's a good time to do so. Also you should clean the dust filter located behind an access door on the rear (right hand side as your are looking at the rear) with a handheld type of vacuum device.
After I completed ALL of the above procedures my WD-62525 was better than I remember. I bought it in 2005 and the picture quality has never looked so good.
The screen is as light as a feather but 62" is awkward. It is recommended you use another person to hold the screen but I work best alone and it was a breeze.
GOOD LUCK.
Dec 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Dust behind screen
If you are familier in opening it then switch off your mobile and remove battery then open its cover and gently wipe with soft cloth and close the pannel. Then re-insert the battery and switch it on.
CAUTION: Dont use IPA or andy alcholic substances.
Good luck
Nov 23, 2007 | Nokia N73 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
