Question about Toshiba e-Studio 35 Copier
E-studio 28 copier
Just moved and when I put my copier back together(finisher back on machine) I get a message to "attach finisher to copier". It is attached but on the finisher PC board lite 3 is steady, lite 2 is off and lite 1 blinks. Can you help?
  • Toshiba Expert
  • 1,326 Answers
You may hve to adjust the finsher to close with out any force. There has to be a inter-lock switch that has to be closed to show that the finisher is closed.
Posted on Jul 16, 2008
Toshiba estudio 282 has error code cc90--how to reboot copier?
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
Apr 06, 2011 | Toshiba e-STUDIO 282 Black and White...
Toshiba e-studio 28 copier
Check that all the door are well closed and in place.
Jul 15, 2008 | Toshiba e-Studio65 Copier
How do I move the finishing trays down? Toshiba estudio 520
There is a hole in the bottom of the finishing trays on the bottom left hand side (towards the back of the copier.) If you stick a slender object ie. screwdriver and then push towards the back of the machine it will release the tray lock and you will be able to slide the trays freely.
Sep 05, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
E-studio 810 problem
There are a couple of different switches that could be out of alignment, or not "making" when you reconnect the finisher. If you will look on the copier, at the latch that connects the finisher to the machine, you will see a pointy shaft about 2 inches long. This rod comes in contact with a switch inside the finisher. There is a metal actuator on this switch that could need adjusting. Not a difficult job, but it will require you to take a few covers off. Also, there is a black push button on the finisher that is actuated when you push the finisher to the machine. If you are looking at the back of the finisher (the side that connects to the machine) it will be on the lower right hand side. It it operated by a connecting rod inside the finisher. This rod could have come loose. Again, not hard, but requires cover removal. Also, when you locate this particular push button, try manualy pushing the switch to see if this makes you message go away.
As for the black spots, this could be any number of things, but I suspect that that it might need a cleaning blade and brush, and maybe just a good cleaning in and around the drum unit.
Hope this helps,
C
Sep 27, 2008 | Toshiba E-STUDIO 650 Copier
Jamming
I have a couple of Toshiba machines with finishers in my office. I don't know if they use the same one as the 28 uses.
Is the rollers where it is getting stuck at have a dark cover with the number 1 on th handle?
Aug 14, 2008 | Toshiba e-STUDIO 28 Printer
Konica 7020 fault F28
f-28 codes deal with a corona unit arching.
if its a f-28-1 its the charge corona on the drum unit. more than likely its a f-28-3 though which is a seperation corona arch. these models were notorious for the insulating material that transfers voltage from the machine, to the door then back to the corona would eventually break down and start casuing arching.
what to look for, open the right side door and halfway down you will see a black peice of plastic sticking out that is attached by to screws. this needs to come off, but to get this off you will also need to remove the door opening bar. a total of 4 screws and you can have the black plastic peice in your hand. once off flip it over and open the back cover up. you will see 2 grey peicesof insulating material, one will be burnt the other will be fine. from here on it is up to you as to how you fix it. using an insulating tape that is cut to the opeing is an appropiate fix but it must be able to withstand high voltages. put it all back together and it should work.
Nov 26, 2007 | Konica Minolta DiALTA Di200 Copier
118 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
