Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
LCD MAG Innovision LT916s blak out
I need help to solve the problem with my LCD monitor. I think it has a problem that some people have already told in this forum: it starts for a second and then suddenly black out forever. Actually there is a very faint image in it. But it was so dark. I have already followed the suggestion to replace the six 470uf 35V capacitors. But the problem remains. Do you have any suggestion? Thanks.
    Champion:
  • 293 Answers
Hi...there,
Are you sure you installed to the right side...There (-) side too you know! Also, testing the blue buttons alike caps too....
Posted on Oct 08, 2008
The black screen monitor
Hi...there,
If you don't have one, don't needed. Just replaced the backlight inverter...
Oct 10, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
How do you open a Mag Innovision LCD Monitor LT916s ?
There may be some interior support hooks that keep it together.  look for metal clips between the crease of the front and rear pieces.  Definitely use caution with opening as you do not want to force pressure against the screen.
Dec 21, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
95 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
