FixYa.com
Tags:
Umax Astra 2100U Flatbed Scanner
UMAX 2100U problem... (by 4 users)
By Luisa_K - usenet poster
Just got a Umax 2100u with version 3.52u of the install CD.  I,ve followed
the instructions to the letter and the scanner just isn't responding at all.
When I use the Scanner Test utility it says that there is a connection
error, probably caused by:-
- The Interface card not being installed properly
- The SCSI cable not installed properly.
Now, it's supposed to be a USB scanner - anyone know what's going one?
Cheers
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by flusturd, posted on Apr 05, 2008
downloaded from the link provided and installed the program; scanner is still seen as unknown device on USB hub; attempted to update driver but can't find it anywhere on harddrive or am told *.inf doesn't match my hardware. Is there anywhere to change "unknown device" to scanner and why when you try to set up scanner in control panel USB is not an option?
Comment by Guest, posted on Apr 02, 2008
Totally the same issue - like dead....
Comment by Guest, posted on Dec 16, 2007
I have the next set of drivers for the umax astra 2100u, got them at http://www.nodevice.com/driver/Astra_2100U/get26110.html maybe this will help correct your problem. Haven't tried them yet, will tomorrow.
Best Solution
posted on Aug 11, 2005
FixYa! (100)
Bomber
Bomber - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There is a newer version(3.53U) at their website
http://www.umax.com/support/do wnload.html The only problem is it's a 34.1MB
download. I would try contacting them to see if you can obtain the new
version on disk.   Greg T
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
FixYa! (100)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
Sorry I just checked Vistascan on my machine and it is ver.3.52. The whole
CD is ver.3.53U. One thing you don't mention is what type of operating
system and what hardware(especially motherboard) you have.     Greg T
Solution #3
Helpful (85)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
See if you can try the scanner on a friend's computer to see if it works
there. Also check at the motherboards website to see if certain types and
/or brands of hardware have issues with that board. What chipset is on the
board? Some people have trouble with Via chipsets. I had an Epson 610U(USB)
scanner and could not get it to work reliably on my old board(Tyan 1590s).
There is a couple other avenues you can take. You could install a PCI USB
card if you have an extra slot and interrupt or try a powered USB hub. I
would first check the scanner out on another computer.   Greg T
Solution #4
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
I'm using Windows 98 and a PC Chips 810LMR motherboard.
The USB port works OK as my printer has been working happily!
Sean
Solution #5
Not Rated (0)
Bomber
Rating: 0%, 0 votes
Checked it on another computer - same problem so it must be the scanner!
I'll be taking it back to the store tomorrow!
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Umax 2100u problem
Hi there im tryin to get my... Answer This...
astra umax 2100u scanner
Hi, I have a problem with my... Answer This...
Astrsa 2100U scanner with UMAX...
I'm trying to set up scanner on... Answer This...
Lamp does not go to full...
I suspect the lamp is... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
