What OS, what operating system.
KVM are very unreliable. , we could talk KVM for days, on this.
no KVM evens stated, brand or model number.
dock ,circa 2008, compatible with V6000
what OS on v6000.
we can not guess what OS you are running, at all.
its a USB problem with the KVM.
V6000 is a 2006 product..
that came with XP or VISA, neither are supported now.
the V6000 must have all its HP drivers installed to work right.
no KVM is guaranteed to work here, with XP its real bad.
XP has bad USB drivers, that are infamous for not working
with odd USB devices, nor many other things,
got SP3 for XP, IF XP>? it fixes some of that be never all.
this is a V6000 to KVM USB issue.
and no OS stated at all.
SOURCE: Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
SOURCE: xb3000 will not charge my laptop battery
discount laptop battery,here you may get your answer.
SOURCE: my compaq presario c300 wont start up, power
This is exactly the same problem as I have. I have changed the power brick and the battery but the problem still exists. PC World were useless and said it "probably needed a new motherboard" although I doubt this is the issue. It worked when I first put the new battery in, until the initial charge ran out. Did you find a solution?
