Solution #18
posted on Aug 11, 2005
pawa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On most of what you stated, I wholeheartedly agree. however, when an AGC spike
is detected in the vertical section electronically or this is a mechanical
imbalance with the video alignment, it will many times affect the audio,
because the video track is laid over top (in a helical pattern) of the audio
track (tracks 1 and 2), control track, and TBC. If any imbalance is found in
the video it can affect the audio. Even in some cases, it depends on the
crosstalk that occurs in the processing circuitry between the video and the
audio portions of the signal processing within the device. Also what might be
affected is the actual frequency response the device is capable of handling for
the audio range. if the frequency response of the device is low, the rest of
the audio portion is sometimes processed in the video section (beyond the range
of audio gets processed in the video).
Just to see if the problem is found in the audio only, I actually have
suggested for the original poster, Gil, to connect up a CD player to the VCR,
record onto VHS tape a stereo signal (in all audio modes) and in SP and EP tape
from the CD source. He can even connect up the VCR to an audio amp to test it
and confirm it to see if it is indeed a problem with the audio in the VCR.
Subject: Re: HI FI static question?
Date: 4/28/01 10:58 PM EST
Message-id: <20010428235811.03140.00000081@ng-fm1.aol.com>
But not SCMS as we know it in CD audio. SCMS forces the CD copier to convert
the PCM encoded audio into analogue midway, then back into digital during
duplication of CDs outside the predetermined limits. Duplication would still
be possible, but the quality of the duplication would not match the quality of
the original because of the D-A-A-D conversion steps in the interim of the CD
copying process.(Which is why computer based setups are better, as they don't
have to deal with this SCMS crap.) As for the copying MacroVisioned materials,
I believe that the GoVideo decks would detect the AGC spike in the vertical
blanking of the source and would stop duplication upon detection, returning a
"copy protected" message. Non-MacroVisioned materials, however, shouldn't
trigger this, nor would the dual-decker encode the copy with "protection
coding", although such a thing is conceivable by adding some kind of
information in the vertical blanking. Either way, this would have no bearing
on the quality of Hi-Fi audio playback (which is AFM analogue to begin with),
as per the original poster's statements. His causes would be worn or dirty
parts in the tape path, or, most likely, a worn tape. - Reinhart
