Question about GE WDSR2080D Top Load Washer
GE washer model WHDSR209
Hi My washer fills the tub and skips the wash cycle. I replaced the cycle knob for it was worn and had the hose blown out so that it will fill correctly but now it fills and skips the cycle. Fills and then spins out the water no wash cycle any suggestions?
Thanks
    Problem Solver:
  • 11 Answers
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Posted on Jul 28, 2010
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
May 15, 2010 | General Electric WHDSR209DWW Top Load...
Ge model wbse2090a washer over fills in the rinse cycle
Clogged pressure switch hose at the tub on left front side of tub pull off and use a small screwdriver or a pipe cleaner to clean.
Feb 22, 2010 | GE WBSE2090A Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
GWWJRR4170E4WW WASHER WONT STOP FILLING WITH WATER. pRIOR TO THAT IT WOULD AT RANDOM SKIP CYCLES OR NOT SUT OFF AT THE END
pop open the front. Check the little 1/4 in hose going to the side of the tub. It may have gunk build up inside it blocking air flow. Its the pressure hose that tells your water level switch how much water is in the washer. Clean it out as well as the port it attaches to.
Dec 01, 2009 | GE WJRR4170E Top Load Washer
When i turn on the washer the water never stops running and it is overflowing into my floor
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Thanks.
May 26, 2009 | Washing Machines
Washer not going in cycles
Where you attached the new hose on the side of the tub, you must remove that hose and insert a small wire in the hole in the cup and clean out the soap scum. Re-attach the hose. Set the washer on spin and run a spin cycle. Then retry your wash cycle.
Make sure the new hose is not pinched anywhere.
Apr 24, 2009 | GE WJSR2070B Top Load Washer
GE Washer Model WJSR2070B2WW overfills only on Rinse Cycle
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 07, 2009 | Kenmore Oasis 27042 Top Load Washer
GE Washer Model whdrr418e1ww overflows the tub!
Feb 20, 2009 | Washing Machines
GE WDSR2080D Top Load Washer Logo
301 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
