Castle ranges don't require a electrical plug. If converted to LP/propane make sure the water column (WC) is set to 10 inches. If it is less you will have pilot light problems even if the thermocouple is strong. If set at 10 inches, most likely problem is the thermocouple. Correct replacement at Castle is approx. $25. The manual for current ranges should cover most issues but the Castle stopped making the C series ranges in the 80s. All controls and most parts are still available.
SOURCE: Comstock f3226-24 for Residential Use
yes but you might have to upgrade your electrical plug in some of them use more amperage than a home is set up for at the circuit breaker. please check into that before you make the change
SOURCE: We have a C330 Comstock
The design pressure for Castle ranges on Natural gas is 4" W.C. (water column) Make sure you change or convert the pressure regulator in the rear and change the orifice tips on all gas valves
SOURCE: The oven pilot light on
The greatest chance is the thermocouple is bad and not allowing the
gas to continue to flow.. This is easily replaceable with simple hand
tools and most hardware stores have them. They are sold by the inch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
