Question about Whirlpool Kitchen Ranges
My whirlpool combi oven can take up to two hours to heat up to a cooking temperature. Any ideas
  • 254 Answers
You may have a faulty oven sensor, it is located on the back wall of the inside of oven.
Posted on Jul 15, 2008
How do you turn it on and set temp
ELECTRIC RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesPress the number keypads to set a temperature other than 350°F (175°C) in 5° ...Timed Cooking allows the oven to be set to turn on at a certain time of day, ...
Oven Temperature Issue ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../oven-temperature-not-same-as-set-t...
Sub?ZeroOvens will heat up higher than the oven temperature set point and then turn off. ... If oven temperature is off on an R or GR Series Gas Range, ensure that the ...
Oct 29, 2015 | Kitchen Ranges
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Whirlpool gas oven won't heat to proper temp. Biscuits at 450 take an hour and 15 mins to cook and brown. What could it be?
    The oven has a temperature sensor inside. The sensor tells the oven when to go on and off. It may need replacement. The sensor is protrudes from the back left wall of the inside of the oven. Make sure that it is fully plugged in and that it is not covered with any goop from the oven. The other things you can check is that nothing is obstruction the heat. That means NO foil or coverings on the bottom of the oven. It blocks the heat vents and can damage your oven. Underneath the floor of you oven, you will find the gas jets.The flame should come out blue and steady. It it is sputtering and orange, the little holes might be blocked. Clean carefully.
    Nov 15, 2009 | Whirlpool GS460 Gas Kitchen Range
    Oven not heating to correct temperature
    Replace the oven glowbar ignitor. It is too weak to keep the gas valve open.
    Aug 19, 2009 | Whirlpool GS460 Gas Kitchen Range
    Oven Doesn't Even turn on
    The oven thermostat controls the oven temp. It is not working and you need a new one.
    Jul 01, 2009 | Roper FGP305 Gas Kitchen Range
    Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
    could be a blown element if not it could be a safety cut out or the stat
    May 17, 2009 | Whirlpool AKZ159IX Oven
    Oven modelakz 1467 type fcew16 pre heat works but will not heat up after that grill is fine oven u/s
    if it isn't cooking, the most likely cause is the door seal is not sealing, though the thermostat control may be bad instead, if the oven cooks, but can't be used to set the temperature or the timer if you can't set cooking time.
    Dec 05, 2008 | Whirlpool Kitchen Ranges
    OVEN TURNS ON BUT WONT HEAT UP.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
    Gas Oven Problems
    oven starts to heat then stops heating
    Nov 22, 2007 | Ovens
    Kitchen Ranges Logo
    59 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
