Question about Dell 5100cn Laser Printer
Error message processing LPD. can get the message to clear and printer will not operate. tried resetting.
  • Anonymous Mar 14, 2014
    not printing + message processing LPD
  • 4 Answers
Lisals, are you printing from a server? i may be able to help you... not 100%, but will try.
Posted on Aug 20, 2008
/usr/libexec/cups/backend/lpd failed
This sounds like a printer issue rather than something wrong with your Mac. When you refill your printer ink cartridges the ink level setting won't change, and if you let the ink level go down too far before refilling the printer marks the cartridge as empty and locks it out. (something like that)
Try this... It should work on most newer model printers.
Shut down your Mac. (important) Turn the printer off and leave it off for one or two minutes. Turn it back on and wait until it goes through all of its whirring and clicking and chugging start-up noises. When it's quiet you should end up with a flashing "E" or an upside-down "u" on the display. Find the Reset or Stop button on the printer and hold it down for 6 seconds. The display should clear and show the number "1".
Turn on your computer and print. If it works, you're done.
If that didn't work pull down the Apple menu and choose "About This Mac". If it says Version 10.6.8 you're about to spend $29 because the message "/usr/libexec/cups/backend/lpd failed" was common with that version of OS X, and that was the last version of Snow Leopard 10.6. Click the "Software Update..." button which will open the App Store. Shell out your 29 bucks for Mavericks OS X 10.9.
The only other solution would be to replace "lpd" from a different computer that's running 10.6.7, which is doubtful. (unless you have a backup)
Good Luck!
Oct 23, 2013 | Apple MacBook Pro Laptop Computer with...
How do you clear memory - its telling me its full but I have no message saying cartridges need replacing
Issue: ERROR LCD: MEMORY FULL
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the <ON/OFF> button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the <ON/OFF> button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
Aug 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error message 5b00
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the button again.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  3. Press the button repeatedly five times.
  5. Press the button to power the printer back on.
    • This procedure will not resolve a physical hardware issue.
      For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.
    • This procedure will not resolve all service errors or LCD related anomalies.
      Service errors appear as four characters (a combination of alpha and numeric codes).
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Cannon MX340 printer - error code 6500
If the printer is not working properly or to clear memory try this:
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
Or Try This:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
Or Try This:
Reseat the printhead (printhead may also need replacing)
Aug 13, 2011 | Office Equipment & Supplies
Have a Cannon MX340 7 when trying to print the Alarm light blinks & message say Printer error 6500
this could be bad feed rollers... clean them with rubbing alcohol and a clean cloth...
if not then try
Or Try This:
Or Try This:
Every time i try to print, the computer doesn't seem to see the printer and it stops the job. error message # 306. very aggravating!
That error message usually means you have a communication error. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again
If that doesn't work, try this:
1. Start Home Applications, go to Utilities, select Utility Printer Setup
2. Hold down the "option" key and click on "More Printers" button
3. From the main menu, select "Advanced"
4. In the next dialog box, under Device: select field "LPD / LPR Host or Printer"
5. In the device of the "URL:" lpd://PCName/PrinterShareName
6. Click the "Add
If that doesn't work either, check your router settings.
Mar 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
"Put in cartridge" error message
Issue: ERROR LCD: PUT IN CARTRIDGE
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Error message "Not Enough Memory".
The update process failed because the updated GWES.EXE file is in use by the operating system. To correct the situation: 1. Double Tap "OK" to clear the error message. 2. Double Tap "OK" to complete the update process. 3. Double Tap "My Computer". 4. Double Tap "Program File" folder. 5. Single Tap "GWES" ICON while holding down the "ALT" key. 6. Single Tap "Delete". 7. Single Tap "Yes". 8. Perform a "Soft" reset.
Sep 15, 2005 | NEC MobilePro 800
Tried to install the update file MP77_UPDATE.CAB twice and got the error message "Not Enough Memory"
Sep 15, 2005 | NEC MobilePro 770
Dell 5100cn Laser Printer Logo
1,632 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
