Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My hotpoint washer is stopping mid cycle if i dont pump the water out it floods it will only work on thr h cycle
  • 57 Answers
Posted on Jul 15, 2008
My hotpoint aqualtis will only select the drain cycle or the slow spin cycle. There's no blockage as ive removed all pipes at the back and cleaned them.
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
see the diagram attached.
Sep 30, 2012 | Washing Machines
Hi. My Whirlpool Duet Sport washer stopped mid-cycle and is flashing F-. I can't open the door. Help!
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Mar 21, 2011 | Whirlpool Washing Machines
The washer floods at the end of the cycle the pump is working this i know because when i manualy lift the mushroom float it pumps out could it be that there is a membrane in the mushroom float that is...
I'm not entirely sure what you mean by "floods at the end of the cycle". Is water leaking from the washer and where from?
The mushroom float isn't a water level sensor to determine when the washer should pump out. It's a second level safety feature to prevent flooding if the washer overfills. The flow meter regulates the water level in the washer.
Your pump is obviously working and there is no blockage in the drain hose, etc as the water pumps out when you lift the mushroom float. It sounds like the pump isn't receiving a signal from the controller to pump out at the end of the wash cycle. Lifting the float bypasses the controller and runs the drain pump.
Please try the following simple test:
1. Switch the programme selector to "Off"
2. Empty a bucket of water into the bottom of the washer
3. Turn the programme selector to any wash cycle
4. Press and hold the Reset button (start/stop) for at least 3 seconds. The washer should drain.
Please try this test and let me know if the washer pumps out. Please can you also be a little more specific about how and where the washer is flooding.
Mar 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
I have a hotpoint wd420p washer dryer and its stopped mid cycle. its full of water and i need to know whats wrong
To fix the problem I stripped down the pump and discovered it was jammed with a hair clip!!
Aug 02, 2008 | Hotpoint Washing Machines
Not draining and flooding my kitchen!
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wf860
not sure about the f04 code but if its still full of water try putting the washer onto a drain cycle if the water does not drain then your pump is either blocked or faulty to check if its faulty pull the washer outnow take the drain hose and place into a bucket low to the floor if it comes straight out then the pump is faulty what it is is they have a magnectic part which goes down if the water doesnt come out its blocked you will have to take the washer outside tip it backwards but dont put it on its back now undue the sump hose which is situated in the centre of the drum pull it the water will drain out now undue the 2screws under the pump pull out undue the pipes you should see the blockedge if not could be in the drain hose itself m8 let me know how you go on if the pump needs replacing shouldnt cost no more than £20
Nov 16, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
