Question about Zebra 105Se Thermal Printer
Right side of label faded or blank after replacing printhead
I replaced my printhead and now the right side of the label is blank or faded. I have tightened the printhead assembly as much as possible but still no luck. If I put a slight amount of pressure on the printhead when printing and it works fine.
  • dswaw Jul 17, 2008
    The first 4 suggestions are not the problem. The entire label is printed when I put the old printhead back in. It just has lines running through it since the printhead was bad. I don't have a maintenance manual so I am not sure how to do suggestion 5.
  • Anonymous Jan 02, 2009
    The print head has been replaed but it still cuts off far right character of lable. is 104 0/8 MM the widest setting? is there another setting for the right margin?
  • 38 Answers
Things to check:
1. Move the pressure arm further towards the outside of the printhead. Adjust if needed using only the minimum pressure required in order to achieve uniform print quality.
2. Inspect the printhead to ensure it has properly engaged the alignment pins. I have had after-market printheads that did not line up correctly and required "surgery" to make them properly seat on the mounting pins.
3. Check for worn platen roller bearings. If they're are sufficiently worn, one side of the platen roller will be slightly lower than the other.
4. Consider replacing the platen roller. They do wear out and require replacement. Zebra part number 40038M IIRC.
5. Check the printhead parallelism adjustment. The procedure is in the maintenance manual.
Steve
Posted on Jul 17, 2008
  • LazerTek Jul 18, 2008
    Trust me, after having worked on Zebra printers for 20 years, it IS one of the above items.
    Since you have now reported that the old printhead does not exhibit the same fading, a bit of info that would have been helpful to include in the first place, I will eliminate # 5 as being a likely solution.
    My recommendation is to replace the platen roller due it having worn to the old printhead.
    As the Nike commercial says, "Just do it!"
    Steve W
    LazerTek, LLC
Printer not Printing barcode label properly
best guess would be a thermal printhead has an element out and needs adjustment. However with out a model number and a picture of the printout that is the best I can do.
Aug 24, 2015 | Office Equipment & Supplies
The printing is fading, more so on left of label, but also on right side of label
Try cleaning the thermal print head. If that doesn't do the trick, the printhead may be defective.
Jan 07, 2011 | Zebra 105SL Thermal Label Printer
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
I want to adjust the printing coz its prinnting on left side my barcode label size is from the right side is having more space
Not too sure what you mean here. If the print on the left side is Ok and faded on the right side, then the position of the printhead pressure toggle may need to be adjusted. Make sure it is positioned over the center of your label.
Hope that helps !
Apr 21, 2010 | Zebra 105Se Thermal Printer
After changing the print head and setting the Ohm resistance, the left side of the printed labels are faded. I adjusted both head pressure and slid them back and forth but I can't get it to print right....
It's very possible the printhead wasn't installed correctly. It's pretty easy to get it wrong, as there are two pins on the latched printhead bracket that have to fit into two holes on the printhead itself. You have to get the alignment of these pins and holes just perfect before you tighten the screw. You have to make sure the aluminum plate on the printhead is sitting flat against the printer's printhead bracket before you turn the screw on top of the bracket.
Sep 24, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Prints faded
Hello mvjv,
To solve the faded prints you need to clean the printhead twice by going to the software and click the "?" mark icon on the upper right corner of the software window and then under General Links select Maintenance then choose Clean Printhead - do it at least thrice to unclog the printhead system. Then try making prints... If still cannot solve call Kodak Technical Support.
I hope I have been some of help.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
No printing on right side, I replaced the imaging drum but that did not solve the problem.
There are two possible solutions to this common problem.
1) The Cyan cartridge may not be in 100% of the way. If the handle of the Cyan cartridge prutrudes even slightly, it can obstruct the printhead for the black developer. Remove and reinstall the Cyan cartridge and test.
2) The printhead is dirty, with some toner spillage on the printhead. All new imaging drums also include a new cleaning pad for the cleaning wand.
The cleaning wand is designed to clean toner off of the printhead. you can see this in your printer manual, but basically, just open the front cover, pull the the blue handle on the right side forward ( this opens the access cover for the cleaning wand on the right side of the printer ).
gently pull the cleaning wand out ALL THE WAY, then slide it back in ALL THE WAY. do this several times.
The cleaning wand is intended to travel across the print head in only one direction, which is why you should make sure that it is pulled all the way out.
One of these two solutions should fix your problem. If the problem is resolved, but then reappears after a short time, then you have a defective developer that is leaking toner on the print head. The color of the defective developer can be determined by the color of the cleaning pad after cleaning the printhead as discribed above.
Sep 07, 2008 | Dell 3100cn Laser Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
457 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
