Question about Espresso RMI La Cimbali Espresso Machine
Espresso machine Hello, When I turn the machine on,- about A minute later- I hear a loud bang, this has happened every day for the last month. Other than that the machine operates normally. What could that be? Thanks ALi
    President:
  • 1,618 Answers
Could be the contactor (Located in box under drain tray)for the elements kicking in (may be worn/going out)
Posted on Feb 26, 2009
No Power after loud pop sound, is the power switch bad?
It is probably a bigger problem than the switch. If you are not experienced in working on electric appliances, you need to take it in to the repair shop.
May 23, 2015 | Nuova Simonelli Premier Maxi Espresso...
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
Hi, At least once a day when I'm driving I hear a loud banging noise (clunk). It only happens once, but when it happens you feel it under the passenger side. The noise only happens when I'm dr
I had a noise like that once in a full size van it turned out to be the ball joints onthe passenger side might want to get them checked it could have been fatal for us
Nov 02, 2012 | Toyota HiAce Cars & Trucks
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Very occasionaly ( 3 times in the last 4 months ) when i decelerate at a corner and then accelerate I have a loud bang. It apears to be the gearbox. Other than that I have no problems with gear changes...
If this happens when you turn both ways, I would suspect an engine or transmission mount. When you accelerate the engine is being lifted somewhat off the frame and the bang would be when it comes back down. If you only hear it on say a right turn, then I would suspect a CV axle or possibly a ball joint on the right side. Hope this helps.
Aug 30, 2011 | 2003 Porsche Cayenne
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
Loud bang
John,
What you are hearing is popping caused by thermal expansion inside the evaporator enclosure during its' defrost cycle.
Depending on your make and model, it'll go into defrost every 8 to 12 hours of compressor "run time". That is, the defrost timer "monitors" how long the compressor runs and after it accumulates the pre-set "run time", the timer then shuts the compressor off and initiates its' programmed defrost routine. This routine lasts for 20-30 minutes, or until the defrost thermostat opens.
The defrost routine sends 120 volts to a heating element in the evaporator compartment which gets red hot. This sudden temperature change (from below freezing to warm) causes the cabinet to expand slightly. That's when you hear the "Pop".
I hope this helps, John. Thanks for using FixYa, and don't forget to rate my answer.
SG
Apr 02, 2009 | Freezers
Bean Grinder
Hard to say when i´m not have the machine in front of me, i think it can be the printed circuit card.
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has...
mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Jul 19, 2008 | Hoover Washing Machines
Espresso RMI La Cimbali Espresso Machine Logo
41 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
