Question about Lands Phones
Can i put a caller picture and assigned ring tone or a bluetooth sent pic or tune to each number in my w9101i? i have tried but cant seem to do it.thanks
Go to menu then organiser, select media album, then go to my music. Find the track you want from your list of tunes, then select options and scroll down to Use As then again scroll down to Contact Ringtone the phone will then take you to your address back where you can select the contact you wish to add the tune. Same instructions would apply for photo, just select from media album and select pictures?
Posted on Dec 01, 2008
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Jul 10, 2007 | Motorola Mobility E815
Somebody sent me a tune by bluetooth from another nokia.but everytime i try and use the tone i keep getting.unable to open.file type not supported. thanks.
meaning the tone that was sent to you is not compatible to your phone due to different file so you cant do anything about it but to delete that tone :D
Oct 04, 2010 | Cell Phones
I want to have different ring tones for in coming calls one for work related one for personal. How do I sent up my LG U990 mobile to do this ?
your contact address must be realigned. You must put all your family and friends into special groups which is in the menu - contacts.. Now if you take options there is a key for assigning ring tone for this group, so selct and assign.
Do the same for the business and post them to the said groups when you set up the contact list.
In fact you can sub divide to different groups with diferent tones so as to identtify when the call comes through.
Sep 19, 2010 | LG Cell Phones
How to set mp3 song from memory card as your caller tune
I think that there have been some mistake.....Caller Tune means the ring-tone which is hearing by someone who is calling you.So you cannot set the caller tune yourself, it is provided by the Sim service provider.Here However, Ring-Tone means the tone which you are hearing when someone is calling you.We can easily set this tone by using....Menu......>Profile...........>Ringing tone setting....Set the tone what you wish............................
Aug 10, 2010 | Nokia N73 Cellular Phone
I bluetoothed ring tones to my new phone. it automatically placed them in the music player. i cant figure out how to assign them to caller custom ringtones
Goto your address book, click on the contact you wish to add a custom ringtone to. Press the menu key to select "edit contact." Once you are in the edit mode, click the menu button again and select "add custom ringtone. You can click the present ringtone to bring up the browse slection. From there you can find your bluetoothed ringtone.
Hope this helps,
Bill
Sep 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have an LG Shine CU720. How do I assign a voice control so that I can say one or two words to have the phone automatically dial the number. Also, how can I assign specific incoming ring tones for...
you have to save all your contacts to your phone and you will be able to set ring id for each number, and be able to have pictures for each number.
Apr 21, 2009 | LG Shine CU720 Cellular Phone
Ringtone not working
u need to go contacat list then
contact seting and then u get a option of image used as wel as ringtone used or assin tone then u can set specific tone for each number..
Mar 02, 2009 | Sony Ericsson K790i Cellular Phone
Caller picture and ring tone
Caller Picture:
i) go in the option Phone Book---> Add a New Entry----> To Phone(Not in To Sim)----> you will get all        option such as name, office no, personal no, caller picture, caller video..
 you will get these option only when you store the number or new entry in the phone memory rather than sim memory
                                                            OR
ii) type the number you want store and click the option save and now save in the phone memory rather than the sim memory, you will all option such as name, office no, personal no, caller picture, caller video..
ring tone:
go to memory card or any other place where you ring tone files or song files are present try to highlight it(dont click it) and at the bottom you will 'option' click on it you will get a list of option in that you will have 'set at ring tone' clik on it and you'll be able to set your own ring tone....
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
J700
go to contacts and edit the contact u want to assign the tone ,choose option ring tone and choose the location the mp3 in ur phone and select the mp3 and assign it.
Oct 23, 2008 | Samsung J700 Cellular Phone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
