Question about Microwave Ovens
The stop/clear and start/stop buttons fail to work on my microwave
  • smithnet Apr 07, 2009
    I have a new DCS microwave oven. The book says to push the stop/clear button to begin programming. When I push the button, nothing happens and the microwave will not start operating
  • Microwave Ovens Master
  • 9,086 Answers
Please reply back with your brand and model number so we can help you.
This is usually caused by either a bad door switch, a loose door switch mount, a failing keypad, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please write back with your brand and model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Push button of lg microwave stop/clear, start/quick start & micro is not working
Jammed due to dirt.
Power supply transformer deffective.
One button is stuck shortcircuiting the board.
Nov 06, 2016 | LG Microwave Ovens
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Can't unlock kennmore microwave, tried the start, stop/clear button it does not work
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works,
see this link
http://www.fixya.com/support/t8306273-unlock_digitals_butons
Feb 14, 2013 | Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
It just stop working. when I push any buttons
A component is failing perhaps..
To try and clear it - unplug it for several minuets and plug it back in..
IF that does not work - it would need to be looked at by a service tech,, test components,, diagnose and repair..
Have a great day !
Oct 06, 2009 | Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Unable to start my microwave. keep on blinking after plug in
It sounds like your keypad or controller may have failed. This is a problem with the control panel assembly, which we repair nationwide for $39.95 in most cases. Full details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 12, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
