Question about Singer Vacuums
Singer touch tronic 2001 trying to refill bobbin. bobbin does not turn. needle does not catch.
I'm having the same problem...I followed the directions but nothing seems to be working.
Posted on Aug 27, 2010
Can not catching the bobbin tread at the bottom
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 18, 2016 | SewShop.com Singer Model 347 Instruction...
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
Mu Singer Futura II model 920 hand wheel seized up-it will not turn. any ideas?
Turning towards you? that is correct. It could be something else that is wrong, like needle hitting the plate, thread jammed etc...and you think it is the handwheel when the handwheel is just not turning reflecting something else. What I always do is take everything out and off...bobbin, bobbin case, feed dog plate, etc...and even remove the needle. Take your brush and get every last bit of lint out of the areas it might be. Something is hung up. When you put your needle back in, make sure it is up all the way, and use a new one. Maybe this will help, but if not, call Singer or take it somewhere as it might be a simple fix.
Feb 13, 2015 | SewShop.com Singer Model 920 Futura II...
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
I need threading diagrams for singer touch tronic memory 2005. Can you help?
Here you go:
http://www.tandtrepair.com/Athena2000M/FreeStuff/Threading.pdf
May 20, 2011 | Singer Vacuums
Bobbin not threading through, spool thread is gathering in bobbin catch and not sewing - just clumps of thread
It would appear to be threaded wrongly. Pull all the threads out, check the visible upper tension discs for broken threads then re-thread top and bobbin, making sure the pressure foot is up when you re-thread. Bobbins should normally turn clockwise when the tail of the thread is pulled. Make sure thread has gone under the tension spring.
Oddly enough, a blunt needle can occasionally cause this problem so if all else fails try changing the needle. Good luck
Mar 23, 2011 | Vacuums
I have a singer 600E touch and sew. I accidently took out the bobbin case and can't seem to get it back in. Can you please tell me how? Thanks
Open the slide plate, and remove the needle plate.The needle plate should be raised by a lever on the right hand side of the bed.Move it to the left, then raise the needle or take it out.It is also easier if you remove the sewing foot.Once you have the slide plate moved towards you you will see a black piece of metal in the front right corner of the bobbin area.Lift it up and slide it to the right.Position the bobbincase with the metal flap that locks the bobbin in towards you so when you lift it up it is on the end closest to you.Make sure the bobbin case is in the groove of the hook(the round thing that spins when you turn the handwheel)once you have the bobbin case in position you bring the black metal pieceover to the left and it will drop down to secure the bobbincase.Turn the hand wheel towards you the bobbincase should stay in place and the hook should turn around it.If it turns smoothly replace the needle plate,close the slide plate,screw the foot back on and replace the needle.You are done. www.sewvac.com
Feb 01, 2011 | Vacuums
Vacuums Logo
341 people viewed this question
Top Singer Vacuums Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
