Question about Whirlpool 24 in. DU900PCD Built-in Dishwasher
No Power My Whirlpool Dishwasher DU900PWKQO was working yesterday and now does not have power to it. Is there a reset button to press or can a dishwasher just stop working?
  • 254 Answers
You probably have a bad door switch assm, there is no reset on this unit, if you have a bad door switch the unit thinks the door is open so it won't start.
Posted on Jul 15, 2008
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
I need to know where the reset button is on my whirlpool dishwasher
check the fuse inside the door panel on the control board
May 12, 2012 | Whirlpool Dishwashers
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any...
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Mar 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool Dishwasher cleaning light stays on
Try unplugging the machine from power to reset the program, if that fails you may need the control panel replaced.
Apr 19, 2017 | Whirlpool Dishwashers
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU900PCD Built-in Dishwasher Logo
262 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
