Question about Samsung SyncMaster 915N 19" Flat Panel LCD Monitor
Samsung SyncMaster 915N monitor
After one of Microsoft's patches, the Samsung SyncMaster 915N monitor goes black in 1280 X 1024 resolution. works OK in 1024 X 768. Monitor is attached to a Dell Optiplex 620 using the integrated graphics adaptor. System Restore to date prior to patch installation didn't fix so maybe the patch is just a coincidence.
    Scholar:
  • 101 Answers
Go into advanced settings from the settings tab of "display properties" and select the "monitor" tab, from there, try changing the refresh rate. Toggle "hide modes that this monitor cannot display" if you do not see any other settings in the drop down other than the one that is already selected.
Posted on Jul 16, 2008
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
After 5 years with no problems, my Samsung SyncMaster 915N monitor is blank with the exception of an error message that says something about needing optimum resolution. At first we thought it might be the...
The optimum resolution for this monitor is 1280x1,024 @60Hz.
The resolution setting is done at the PC not at the monitor.
After 5 years, more likely components failure will be the filter caps in the power supply section, that will be the first thing to look for inside. You can see failed SAMSUNG monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Samsung SyncMaster 915N 19" Flat Panel LCD...
MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME ON WHEN I TRY TURNING IT ON. HOWEVER THE POWER BUTTON BLINKS GREEN. ANY ADVICE? THANKS SAMSUNG SYNCMASTER Monitor (black) 739S O seen at the back
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Oct 31, 2009 | Computers & Internet
Samsung Syncmaster 551V Display is too wide
You can adjust the monitor picture size settings & position from the menu button on your monitor.
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Image blur
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Samir.
Please rate the solution and provide feedback.
Jan 02, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Sansung 915N no video
the monitor gets the wrong signal from the computer (refresh rate too high or scan rate too high )
check the screen refresh rate from Display properties / Settings tab / Advanced button / Monitor settings
worse case: damaged hardware
Nov 07, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Samsung SyncMaster 920NW
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Jan 08, 2008 | Samsung SyncMaster 913V 19" LCD Monitor
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Jun 18, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung SyncMaster 240T issues
a) set your screen resolution to 1024 x 768 and then b)go to desktop( right click) properties -->settings--->advanced--->monitor---> change the refresh rate to 72Hz or 75Hz.
Feb 21, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung SyncMaster 915N 19" Flat Panel LCD Monitor Logo
378 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
