Question about Samsung Office Equipment & Supplies
My samsung scx 1400 is displaying paper jam 2 i have lost the guide book and the printer will not opperate
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Posted on Feb 04, 2008
SOURCE: Samsung SCX-4x16 printer error
getting an error while printing from a particular application. Error Printer could not print any more because the port is in use. Printer is Samsung Samsung SCX-4x16 ver 5.56. please help!!
Posted on Jun 24, 2008
SOURCE: Samsung paper jams very frustrating
Unplug the unit and remove the paper tray. Flip it over. Be careful of the floppy paper catcher--don't let it break off as you're setting the printer down.
Look towards the back of the unit, and you'll see a dark grey to black rubber tread about 1.25" long, in the center of a shaft. This is the gripper that pulls the paper into the unit. It needs cleaning.
I used VHS tape head cleaner (amazing--I still have a VCR!) but you could use rubbing alcohol. Put a few drops on a Q-Tip and scrub away at all surfaces of the rubber piece. It won't move, rotate, etc. and don't try to make it do so. The swab will get dark. Use the other end of the swab to scrub the piece dry. Pick away any loose cotton.
Turn it back over, plug it in, and it'll probably work. Did for me after much frustration that I thought was due to bad paper or my paper getting weird from humidity. I didn't think it was a roller, because I had hardly ever used the printer, but that may have been the problem...
Posted on Jul 01, 2009
SOURCE: paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Posted on Sep 18, 2009
SOURCE: samsung scx-4521f paper jam 1 error
As Roipatrick said, for Paper Jam 1 the location of the Jam is In the fuser area or around the toner cartridge. I download the service manual from www.elektroda.pl/rtvforum/download.php?id=362035 and it suggested:
1. If the recording paper is jammed in front of or inside
the fuser. -> 1. Replace the SMPS.
2. If the recording paper is stuck in the discharge roller
and the fuser just after passing through the Actuator-
Feed, Feed Actuator may be defective. ->
2. Reassemble the Actuator-Feed and Spring-Actuator
if the returning is bad.
I found if I push the paper a little bit when it goes in, it can print, so I conclude neither is correct, it is pick-up sponge needs to be replaced. It will cost about $15 parts + shipping from http://www.partstore.com/Part/Samsung/Samsung/SCX4521F/Samsung/Samsung/JC7300211A/New.aspx
So I tight a rubber bend around the roller as showed in the picture and I am printing now. :-)
Posted on Sep 01, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Scan scx 1400 samsung printer
Here download the Drivers for your Operating system here.
http://www.samsung.com/us/support/owners/product/SCX-4826FN/XAA
Apr 09, 2014 | Computers & Internet
Down load the drivers for your operating system here.
SCX 4521F SOME TIME PAPER JAM
pls. send which error message shows in your display , while the paper jam occur.
solution depends up on that error message.
Apr 04, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam 2 displays however there is no paper jammed in the machine
This is caused by exit sensor or the problem may be a small peice of paper is still remaining. Or if its software error which will be cleared from service center. Please approach them.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Sep 09, 2008 | Samsung SCX 4200 All-In-One Laser Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
366 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
