I installed a game that is compatible with vista on my brand new laptop. the game installs but locks up when I try to play.
  • tanya2477 Jul 15, 2008
    No it says it is compatible with windows vista.
  • 177 Answers
Incompatability error.Is the game for 32bit or 64bit?
Posted on Jul 15, 2008
I had my comp. fixed and they put windows vista home premium on here and i can't play my old games that need xp what can i do
You can do 2 things:
1 - try to run them in XP mode  - right click on its icon, then Properties, then Compatibility, check 'Run this program in compatibility mode for' and select Windows XP in the drop down menu and finally at the bottom of the compatibility tab, check 'Run this program as administrator'.
2 - install http://www.microsoft.com/windows/virtual-pc/ , configure it and in it install XP and all the soft with problems, starting with the games.
Mar 07, 2010 | Microsoft Windows Vista Home Premium...
I can not install Boggle on a Vista system
You could try to rightclick the setup.exe, select properties, go to compatibility and run it in Win95 compatibility. You can also try to make a shortcut to the game, then doing the above. There could also be a map called DIrectX on the disk. Try opening the executable in there, install DirectX, then try the game again.
Otherwise you're out of luck. Microsoft doesn't support old games, gets you to buy new ones. I don't like it either, but there's nothing you can do about it but switch back to Win95
Dec 08, 2009 | Hasbro Interactive Video Game Consoles &...
How do you remove Windows Vista from acer 5535. i want to play my games but i got a feeling they wont run since vista is a memory hog. and since its got 3 gig im afraid it will lag alot. games needed to...
If you want to install another operating system on the laptop all you have to do is boot your laptop from your installation disc. You can then format your hard drive, and do your install. Here is the catch; you have to make sure you have all of the drivers for your laptop for that version of Windows. I've been able to play a lot of games in Vista with the Comparability mode turned on. Before you get rid of Vista it might be worth trying that out.
Jul 28, 2009 | Acer Aspire 5535-5050 Notebook
Cannot install it correctly to windows vista laptop
Haha. Not laughing at you.
If you try to play games that old on a new OS like Vista, it won't go. You would have to try to run the game in compatability mode. Which means when you ry to install the game, right click and propeties and check the tabs out.
I tried playing a game from the 90's too, on my computer with Windows Xp, and it did the same thing. I tried lots of stuff, but then I just didn't have time to mess around with it so I left it.
What I'm trying to say is, that Vista is too ahead for the game software. And vise versa. The game code is too old for Vista. Vista would have to downgrade to play the game and that could bring some problems. The computer prosseser would have to work harder and that could cause the game to lag and even the whole computer to lag. LAAAAAG real bad.
Anyways, keep trying and hope this helps.
May 08, 2009 | SoldOut Hand of Fate for Windows
CivilizationII test of time
If it doesn't work the regular way, try installing and playing in compatibility mode. To install in compatibility mode right click on setup -> properties -> compatibility tab -> check: run this program in compatibility mode; to play the game in compatibility mode do the exect same thing ond the game executable file
Mar 17, 2009 | MicroProse Civilization 2: Test of Time...
FM2008 wont start
Is the CD Windows Vista compatible?
Dec 07, 2008 | Acer Aspire 3680 Laptop
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
...problem
I think the game is not compatable with vista like many other softwares, before you buy the game cd you need to check that it is compatable with vista OS.
Oct 04, 2008 | Acer Aspire 5050-3242 Notebook
I cannot download platinum play casino on my new computer it has windows vista
Is platinum play compatable with windows vista as not all games will play on vista even though they play on xp home
Jul 26, 2008 | Computers & Internet
Favourite game wont play on vista
goto properties of the file and in the compatibility tab enable "run this in compability for" and select the OS in which it used to work well... this might help....
Feb 14, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
