Question about SanDisk Sansa e250 MP3 Player
Problem i went to go see my pics and delete one and it froze.what do i do?.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
My sansa disk is froze on the refreshing media screen
This happens often with Sansa Media Players, your best bet is to delete all your songs off the device, then re-add them again. But this time have your device on hold, which is having the switch at the top of the device pushed to the right side. This will make sure nothing happens while the device is syncing.
Aug 03, 2012 | SanDisk Sansa e250 MP3 Player
After deleting the pictures from the memory card and putting it back into the camera, the pictures are loaded back on the card, what could be the problem? When I put a new card it acts like it is froze up.
Sounds like you failed to delete internal memory from setup menu before inserting card, and ALWAYS use camera to delete pics...from internal memory and from card...do not delete pics using a PC, or format card on PC.
Oct 18, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I was playing a video on my sandisk and it frozeI'm not able to turn off the devise or choose another program
You can't play a video on your Sansa Clip/sansa clip plus (based on pic you showed).
If your device is froze, press and hold power button untile device turn off (about at least 10 seconds); then turn it on and check it. If it's still frozen, turn it off again, plug it into computer and delete the video which makes it froze
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
Screen froze up on't do anything
Try resetting it by sliding and holding power button for about 15 seconds. Go to http://www.sansa.com/support for more troubleshooting and FAQs. Hope this helps and don't forget to rate the answers.
Mar 06, 2009 | SanDisk Sansa Clip MP3 Player
How to unfreeze mp3 player
i held in the power button for 5minutes,it shut off,then turned it back on.but now i have another problem,now it wont play my music.i cant get the plan so if u could just tell me what u think or know what to do i would really appreciate it.
Mar 02, 2009 | RCA M4208 MP3 Player
I River Froze~won't scan or turn on or off
There is a small pinhole reset located on the left side of the iriver e100, you may push with a small needle for about 20 seconds and this should reset the device.
Dec 31, 2008 | iRiver E100 Digital Media Player
Camera froze deleting images through iphoto
take it off the cradle try again if it dont work tfer the pic on a cd at any walmart. then format the memory and try again. if it still does the same you might have a bad memory card or bad reader.
Dec 31, 2007 | Casio Exilim EX-S500 Digital Camera
Internal memory problem
they could be on the internal memory try ejecting the card and connect the cameras to the laptop they might pop up then.
Sep 21, 2007 | Fuji FinePix A500 Digital Camera
SanDisk Sansa e250 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
