Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung hlp5063w won't turn on
When it plays it works fine but when you turn it off it does not want to come back on. The lamp light will blink for about 30 secs the the temp light comes on then it starts the cycle over untill the third time it gives up and all three lights blink. I have replaced the bulb and ballast with no change. I have checked the power coming into the ballast and it is there even when the bulb doesn't start. I checked the power at the bulb and there is nothing untill the times it comes on and the voltage just gradually creaps up as the bulb warms. Do I possibly have a bad ballast or is there some kind of control issue that is not turning it on?
  • bal4 Jul 22, 2008
    I have the exact same problem with mine
Posted on Jul 22, 2008
Hlp5063w lamp and temp lights blink and tv doesnt turn on
Look at turn on to see if lamp fires even for a second.
If lamp has not been replaced in 2,000 hrs it is a suspect.
If you heard a high pitched whine or fan like noise before the set failed remove the lamp and look where it faces----is the color wheel shattered or missing pieces?
Apr 11, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Replaced color wheel and the still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Nov 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
I have a 50 inch samsung hlp5063w when i turn tv on lamp light on front blinks
Have you replaced your lamp before? If so you might be starting to get issues with what might be the ballast, but if you haven't replaced the lamp, I recommend you do it since it might have reached the average life time they have.
Jul 22, 2009 | Samsung Televison & Video
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063W 50" DLP Projection TV has a 3 inch black band
Did you check the picture format and adjust for 16:9 in the menu?
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP5063W DLP
no you do not need a bulb you will need to have the color wheel replaced.
Aug 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP5063W turns itself off
rither the lamp door cover switch, or the thermostat has become intermittent..neither one is very expensive but soldering skills are needed
Nov 25, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Jerry Greenberg
Jerry Greenberg
