Question about Dell 5100cn Laser Printer
Problem code 094-911
How do i change transfer roller
  • 4 Answers
Hope this will help... look on google for a dell 5100cn user manual. there will be a pdf copy you can download. it may assist you in solving this. good luck. let me know if it works.
Posted on Aug 20, 2008
When my konica minolta c280 gives me an error codes c2151 please help"
Code
C2151
Description
Secondary transfer roller pressure welding alienation
• The pressure welding alienation sensor doesn't turn OFF (retracting) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is retracting. • The pressure welding alienation sensor doesn't turn ON (pressuring) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is pressuring
Sep 23, 2016 | Konica Minolta Bizhub C280 Color Copier /...
Remove transfer roller 4650
Just curious as to what prompts you to think it needs to be removed?
It is part of that transfer belt assembly that is on the inside of the front door that opens out and down ( hinged at the bottom).
I have only seen the entire assembly for sale.
Easy as pie to change if you feel the need but the machine should tell you when to change it.
go to youtube and search for precision roller , then HP 4600 trnafer belt.
They have a video showing how to remove it and replace it.
Ray Charles could do it.
They also sell the assembly.
Rich
Mar 14, 2012 | HP Color LaserJet 4650DTN Printer
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
My lexmark t620 is printing dark copies and I change the cartridge twice.
Change the charge and transfer rollers under the cartridge is the transfer roller and attached to the top door is the charge rolelr. Part #'s 99a1015 Transfer Roller and Part # 99a1017 Charge Roller.
Nov 17, 2010 | Lexmark T620 Laser Printer
Laser Jet P2015dn only prints in grey not black. Changed the toner cartridge - didn't help. Went into properties menu, looked to see if "econo" mode is on, and that doesn't exist. Help!
Sounds like you might have a transfer roller that needs to be replaced. The transfer roller is under where the cartridge seats and transfers the toner to the paper...If toner is not sticking to the transfer roller it will show what you are seeing....Transfer rollers come in Maintenance kits. If the transfer roller is not the issue....its most definitely the fuser not fusing the toner completely, due to improper heating, to the page giving a lightness.
Oct 19, 2010 | HP LaserJet P2015dn Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Dell 5100cn Laser Printer Logo
1,365 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
