Question about Lite On LVC-9016G DVD Recorder/VCR
Dvd tray won't open
Dvd tray will not open tried several options nothing seems to work
  • Anonymous May 11, 2010
    Do you know if there's a DVD in the tray?
    If so, have you tried to take the cover off to see if you can dislodge the stuck disk?
    Does the player function properly otherwise (still powers on, still displays a menu on the TV screen, etc.)?
Don't take the cover off. Open the door and use a small flat instrument to depress the tray release buttom (it is indented on the lower right hand side of the tray. If there is a disk remove it. Turn off your system and the tray will close. Restart you system and see will the trat open.
Posted on Sep 27, 2008
My ibm intellistation z pro: nothing appears on the screen no ibm sign at start up no nothing also if i try to open the disk drive it won't open which seems weird
maybe a disc stuck in the drive? if you pull down outter door of disc drive (unless you can see the front of the disc tray already) there is a tiny hole on front of disc tray, large enough to get a paper clip wire into, that will release the tray and pop it open
Mar 06, 2013 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
This item has not worked consistently since new. "No Disc" message. Several attempts opening and closing tray sometimes helps, but last time I tried, I could not get it to engage at all. The...
Well i think that the problem is the optical lens, if you remove the optical lens under this optical lens you will see a potentiometer try to adjust it clockwise but small adjustment is needed if wrong adjustment is done your optical lens may not work again. good day and best regards.
Aug 20, 2011 | Apex Digital AD-1600 DVD Player
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
I need to hack the region of the Sony DVD SR500H
Hi there
Follow these steps and your dvd will be able to play discs from any region.
*With the player in stand-by mode (take out any discs and leave it alone for several minutes) press on the remote, in this order: TOP MENU, CLEAR, POWER.
*A menu will appear with several options. Choose Option 2 and then Option 4.
*Type 12450, press enter, then type 00000.
  • Step 4 After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
    *After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
    Thank you for visiting
  • Step 2 A menu will appear with several options. Choose Option 2 and then Option 4.
  • Step 3 Type 12450, press enter, then type 00000.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
    Jul 27, 2010 | Televison & Video
    Pioneer htz-77dv Tray Lock
    We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
    What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
    Jan 19, 2008 | Pioneer HTZ-77DV System
    LG DVD+RW door won´t close
    Deliverance
    this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
    Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
    Lite On LVC-9016G DVD Recorder/VCR Logo
    433 people viewed this question
    Top Lite On Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
