When Kodak EasyShare burns a CD, does it use the ISO 9660 Level/Level2 standard? I burned a CD which has 776 images on it, my Toshiba player will only play the first 200, a friend's Phillips plays only 648. Manfred Rose 250-652-9815
Hello:
Not a solution but a sidestepping . . . :
Rather than pursue the theoretical aspect of the ISO standard I will simply take my CD to the store and ask for a demo. I will buy the unit that can play this kind of CD.
Thank you for your response. Manfred Rose.
Posted on Jul 17, 2008
I have benq combo cb523b my problem is combo not writ dvd
Hi Dear,
First Install the burning software and then try to write the DVD, may you have try to burn without burning software.
Click hear and get the Burning software, see the instruction of mention below.
Data Compilations
  • Burn, backup or copy your files to CD, DVD or Blu-ray Discs.
    Supports recording from command-line and BAT scripts for automating routine actions.
    Supports CD-R/RW, DVD-R/RW, DVD+R/RW, BD-R/RE and DVD-RAM media, including high-capacity double-layer media.
    Supports UDF (Universal Disc Format 1.02-2.60), Bridge and ISO9660 (Level 1-3, Romeo), including Joliet Unicode extensions.
  • Create Bootable CD or DVD. Use it as a very big floppy boot disc for recovery purposes.
    El Torito creation support with advanced options: emulation type, sectors, platform, load segment and boot message.
  • Append or update Multisession discs.
Multimedia Compilations
  • Create Audio CDs. Play a CD on your traditional CD player or car stereo.
    Supports MP3, WAV, WMA, OGG, M4A, AAC and FLAC audio formats and M3U playlists.
    Supports title and track CD-Text, including Unicode.
  • Create DVD-Video discs and MP3 CDs/DVDs.
Disc images
  • Make and burn standard or boot disc images.
    Supports ISO and CUE/BIN image files.
  • Copy disc to ISO image. This feature can be used for disc backup, as well as for disc copying.
Utilities
  • Erase re-writable CD, DVD or Blu-ray discs.
Thanks
Mar 31, 2012 | Computers & Internet
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
Jan 25, 2012 | Microsoft Windows XP Professional...
HOW I DOWLOAD MY COMPUTER PICTURE TO A CD
  1. Check your computer to see that it has a CD or DVD drive that is capable of burning CDs. This drive may be built into your computer or an external drive. Either type should work equally well.
  2. Make sure you have a CD that can be burned. There are two types of CDs that you can use.
    1. A CD-R (Compact Disc-Recordable) is a Write Once Read Many (WORM) optical medium. This means that once the disk is burned it can not be erased. This type disk is usually used for permanent storage. For example; a music CD, a picture CD, or any other type of data that you want to keep permanently.
    2. A CD-RW (Compact Disc ReWritable) is a rewritable optical disc format. This type of disk can be burned, erase, and then burned again. This type disk is usually used for temporary data storage.
  3. Decide on the type of CD you plan to burn. There are many different types of CDs that can be burned and how you proceed depends on which type you are going to burn. The major types of CD that can be burned are:
    1. Music. This type of CD is the type of CD that is normaly burned for use in a home or automobile CD player.
    2. Data. This type of CD is most often used to store files that can be used by a computer. This type of CD can not be used in a standard home or automobile CD player. They are formatted using the "ISO9660" format, which cannot be read by a standard CD player.
    3. MP3. This is a data CD containing only mp3 compressed music files. Because it is actually an ISO9660 data CD, not all CD players will be able to play it. This type of CD can contain a much larger number of songs than a music CD but can only be played on a computer or CD player specifically designed to play MP3s.
    4. Disk image. A disk image file is a file that contains an exact copy of a disk. The most common type of Disk image is an .ISO image. Disk images are usually used for storing an exact copy of a CD on a computer. By using a computer, one can burn a CD from an .ISO image and create a usable CD.
    5. Ripping. Ripping a CD is the process of taking the audio off of one CD and either storing it on a computer or burning it to a second CD, thereby making a copy of the first CD.
  4. Decide on the software you want to burn your CD with. There are many different programs that are designed to burn CD's. Some are built into the computer's operating system, while others are individual programs. These programs range from very simple to very complex. Some of these are free, while others have to be purchased.
  5. Burn your CD. Burning your CD is as simple as running the software that you are going to burn your CD with, putting a CD into your CD burner, selecting the data to be burned, and then telling the program to burn the CD
Feb 02, 2011 | Computers & Internet
Nrg- files , how to open?
you can only open that file and make the icon file visible to your desktop by downloading cd or iso burner through nero, demon or alcohol. because .nrg files is a image extension file generate through software applications cd and iso image burners.
Aug 07, 2010 | Toshiba Computers & Internet
How do I find for DVD BD370 the Multiregion code
Please follow the steps
1.Download http://www.multi-region.net/_media/6000.zip
2.Extract the files
3.Burn the directory RMTM0000 to a CD-R
4.Write mode: ISO format, Mode 1, ISO 9660.
5.Put the CD-R into the player
6.When the Region Management System screen is displayed, set the Region Code to “0” using your remote.
7.Press PAUSE
8.Your are done
Thanx
Jul 22, 2010 | LG Televison & Video
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
Hw can I burn the firmware download to a CDr using
You can't. The CD burning software in VISTA does burn an ISO Image, which is what the firmware update must be burned in. XP DOES do ISO, but not Vista. You'll need to download a free CD burning software (Google "Free ISO Image Burner"), then burn the firmware update you downloaded onto a CD as an ISO Image. Then, update the player.
Dec 17, 2009 | Panasonic SC-BT100 Theater System
I want a software with NRG files to download
A .nrg file is a proprietary CD image file format used by Nero Burning ROM, a utility suite made by Nero AG, to create and burn ISO 9660 CD images.
Other than Nero Burning ROM, a variety of software titles can use these image files. For example, Power ISO, Alcohol 120%, or Daemon Tools can mount NRG files onto virtual drives for reading.
Dec 11, 2009 | Microsoft Windows XP Professional for PC
Hi I can't open a .nrg extension file. pls help me
This is an NERO BURNING ROM File
here are several tools available to convert a .nrg data file into an ISO 9660 CD image.
  • Open Source command line tools include:
  • Shareware tools include:
    • PowerISO — converts from nrg to ISO as well as allows for browsing and extracting individual files from a nrg data file.
    • NRGtoISO — freeware. Converts a Nero NRG file (CD Image) to a standard ISO CD Image file.
    Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Sep 05, 2009 | Lenovo 3000 Y410 Notebook
What video formats can you play with slv-d360p?
Hi al - your unit can play the following formats:
DVD VIDEO
DVD -R / - RW
DVD +R / +RW
CD -R / -RW
VIDEO CD
MUSIC CD
The player can play CD-ROMs/CD-Rs/CD-RWs recorded in the following formats:
- music CD format
- video CD format
- MP3 audio tracks and JPEG image files of format conforming
to ISO 9660 * Level 1/Level 2, or its' extended format, Joliet Kodak Picture CD format.
*(A logical format of files and folders on CD-ROMs defined by ISO)
The player can play DVD-ROMs/DVD*RWs/DVD+Rs/DVD-Rs recorded in the following formats :
- MP3 audio tracks and JPEG image files of format conforming to UDF(Universal Disk Format).
In other words, just about everything. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 12, 2008 | Sony SLV-D360P DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
