Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Broken belt My husband and i took apart the vacuum and found out the belt was broken. how do you replace it? we could not remove the area where the belt is.
  • 372 Answers
Hi.
If you cant easily see how to replace the Belt then I think your Dc07 has A clutch unit.
This type of Dc07 has 2 belts one from motor to clutch & the second belt goes clutch to brush roller.
You will need to remove the clutch unit completey from the machine in order to replace the belts, Its alot to explain so try this site it has service manuals covering this.
http://dysonmanuals.llc.nu/
Posted on Jul 16, 2008
Powerhead will not rotate
Hi jjill
Sounds like you have a broken belt in the powerhead...replace the broken belt and clean the roller bearing area's of debris while you have it apart.
Please take time to rate me
Bud
Mar 26, 2013 | Vacuums
I cleaned the roller on my Dyson DC 07, and after reassembly, it makes a sound like the belt is being chewed. I took it apart a couple times, goes back together fine, but still makes the noise
Hi its Darran at Dyson.
Your machine is designed to make this ratchet noise if the brush bar is obstructed. We would recommend checking the brush bar and soleplate area and removing any blockages or hairs/threads that are wrapped around the brush bar.
Full details on these checks can be found in our Support section online at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hair around belt area
Design flaw. You have to clean that out regularly :)
Mar 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Mar 22, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do i replace a broken belt on a dc07?
the vacuum must be completely torn apart to replace the belt/clutch assembly. be very careful as the parts will break easily
the assy you need runs around $60 or more at a vac repair shop
i have been in the repair business for 20 years, and the dyson is about the worst one out there
get yourself a Panasonic or a sanitair
Dec 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush bar won't turn on
This is extremely embarrassing, but if I can save you some frustration, I'll gladly swallow the humble pill. I had the same problem, after vacuuming an area rug, the brushbar quit spinning. I let it cool to ambient temperature and tried again, thinking that the auxilliary motor that turns the brushbar may have overheated and tripped a thermal cutout. I even took the unit apart and inspected the brushbar motor to ensure the windings weren't damaged and that the brushes properly engaged the communtator.
Ready for the solution? There's a button right next to the power button that has a picture of a brushbar on it. Guess what it does? It turns the brushbar on and off. I cycled that switch, tried again, and: Ta-dah! It worked.
Oct 31, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Push the reset button
Sounds like a problem I had. However, I took the vacum head apart were the belt is to get to the switch that was sticking. the model # on this part is:
Mel Rain/littel fuse
742332
11200000-04
HOLD 2.0 A.
125 V.D.C. / A.C. 60Hz
I took the two connectors of and carfully removed the part. After removal I took apart with a small flathead screwdriver and reset but this is a quick fix and my vacuum begin to work again!
Aug 03, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
105 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
