Water leaking under washing machine - Washing Machines
  • 2 more comments
  • hartshaped Jul 16, 2008
    Mine is too.  It's spinning the water out of the top and it's running down the inside panels and soaking the floor under the washer.  There are no leaks in the hoses.  How can I fix this?
  • SusanMcCloud Jan 30, 2009
    Water is leaking from my washer on the rinse cycle (I believe). I have cleaned out the lint trap on the lower face of the machine but the water leakage continues. HELP!
  • gormus May 13, 2009
    Washer is leaking out of the top of the tub during cycle--
    I have a GE profile one touch
    WPSB908
    any info would be helpful - thank you
  • Anonymous May 23, 2009
    My whirlpool washing machine has water FLOODING from up under it. The rinse cycle just finished
    Novelist:
  • 177 Answers
First posting, remove front panel and look for leaks.
second posting, make and model, it could be serveral things, I need to know the make first.
Posted on Jul 16, 2008
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Washing machine leaking at back
You have a bad water pump or the hose that goes to it is split.
About $40.00 in parts.
Nov 08, 2009 | Washing Machines
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Washing Machines Logo
2,911 people viewed this question
Top Washing Machines Experts
