Question about Toshiba DKT-2020 Corded Phone
Toshiba Strata DK System 2020 phone
We purchased this used system from a company when we took over their lease about 11 months ago and have not had any problems. Suddenly last week, calls stopped going to voicemail. When we call in, it just rings and rings. When we are here and try to call in to the system admin which is 300# it is busy signal (also on our individual intercom lines). Any suggestions?
  • amy273 Jul 15, 2008
    Yes, it is. Stratagy or something. Actually, I just fixed my problem. Someone had stored something in the closet that was pushing on the phone wires leading into the the voicemail box. So, it appeared that all were lit up or busy. Thanks anyway. I am so glad it was a simple fix.
  • Anonymous May 11, 2010
    Is the voicemail system separate from the phone system?
    The voicemail system could be out of space and unable to accept a message so it just doesn't answer.
    The system could be just frozen and maybe a reboot would help ... have you tried anything like that?
Someone had put something in the closet that bumped the phone line going into voicemail system and it was loose.
Posted on Jul 16, 2008
We have a Toshiba Strata DKT3512F-SD system in the office, only the main line actually rings the others just flash but we need to make them ring.. any advise would be much appreciated!! I'm lost!
On the old DK system, it must be done using key strokes from port 005. On the newer CiX system, it's handled via system programming using the Network eManager.
Dec 07, 2015 | Toshiba Lands Phones
NEED TO RESET MY PHONE CLOCK , TIME CHANGE.
Depending on the type of Toshiba phone system, the programming steps may vary slightly but this should get you on the right track.
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redia
Nov 09, 2010 | Toshiba DKT-2020 Corded Phone
How do i change the time on this phone?
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial
Nov 08, 2010 | Toshiba DKT-2020-SD telephone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
Trying to download a users guide for the toshiba KT-2020
The DKT 2020 was used what a few different Toshiba systems. Users guides were referenced to the model and version of the systen rather than the model of the telephone. With that in mind, here's a link for a DK280 system, Most of the features should work ok.
http://www.wedophones.com/Manuals/Toshiba/Strata%20DK%20280%20LCD%20User%20guide.pdf
Feb 15, 2010 | Toshiba DKT-2020 Corded Phone
Need to set my time on my phone
I think this feature is dependent on your system - the phone display is in agreement with the entire network. Check to see what system your phone is on - ours is a Strata DK-280 - and then search Google to find a total solution to changing time.
Dec 07, 2007 | Toshiba DKT-2020 Corded Phone
Phone ringer has turned off following a power outage.
I am assuming you have a Strata VIe system with this phone. I added a website below with all the program manuals. If you have a DK system please look at program 81 to get ringing back. I dont know the programming very well on the Strata VIE systems.
http://www.wedophones.com/ToshibaManualsLead.htm
Dec 07, 2007 | Toshiba EKT6520SD Phone
Toshiba DKT 2020-SD without a manual!
The phone you have DKT2020-SD can be used on many different Toshiba phone systems. For a phone all you will find are user guides. You need to find out which phone system you have and look for the manual for the system. All the Toshiba phone systems say "Toshiba" plus the description on the front cover. Example: "Toshiba Strata DK-280"
Not sure what you plan to change but programming can be quite difficult if you have no experience with it. It does depend a lot on which system you have. Many of the newest systems require special programming software.
Nov 13, 2007 | Toshiba DKT-2020 Corded Phone
We have no designated 200 STATION
Usually the operator's extension is the programming extension. Ext 200 is the default operator's extension.
You dial 200 and it rings a phone line not an individual phone? Do you know what your extension numbers are? (Some people never use them and do not know) If you do know some or all of your extensions, what is the lowest extension number?
For me to get you specific information, it would help to know which Toshiba phone system you have. (Not a phone) The systems all program differently. Did you obtain the manual recently and are you sure it is the correct manual for your specific Toshiba system? Again, the system is not a phone and your phone's model number does not narrow it down. All the Toshiba phone systems have a name and number on the front cover. Example: "Toshiba Strata DK 280"
Nov 12, 2007 | Toshiba DKT-2020-SD telephone
Toshiba DKT-2020 Corded Phone Logo
388 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
JP Services
JP Services
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
