Toshiba SD-P1400 Portable DVD Player with Screen
Problem for Toshiba SD-P1400 Portable DVD Player with Screen
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
By lucaspartan on Jul 15, 2008
My Gigabeat has been working fine. But all of a sudden it will not turn on.
When I press the power button the battery indicator flashes (and looks empty). This would typically tell you the battery is dead and needs to be recharged.
I then try plugging it into my laptop via USB cable to charge, but the same thing happens. The battery flashes for a few seconds and then the unit turns off. I cannot get the unit to charge anymore.
I tried switching the hold on and off - nothing. I tried switching the master slide thing at the bottom and still nothing.
please help.
thats' what happened to mine except my battery just wont work.
Popular Solutions for Toshiba SD-P1400 Portable DVD
Questions and Unsolved Problems for Toshiba SD-P1400 Portable DVD
Do you recommend Toshiba SD-P1400 Portable DVD Player with Screen?
Answer
Answer
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was... (More)
Answer
switch power on/off no good .. broken for sometime i did pushed or press very hard with the... (More)
Answer
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid... (More)
Answer
I have a Toshiba SD-P1400 portable dvd player. I can hear the dvd but there is no picture. HELP!!
Answer
The player does not read the DVD and some VCDs. I have had the problem for months
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba SD-P1400 Portable DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
